Author Topic: Are there bags for 60 percent keyboards?  (Read 4606 times)
Offline roaming pear
  • THE Roaming Pear
« on: Wed, 23 April 2014, 13:08:38 »
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Re: Are there bags for 60 percent keyboards?
« Reply #1 on: Wed, 23 April 2014, 13:15:00 »
I sometimes use a big wool sock  ;D
Offline Zeal
    • Zeal Generation Inc.
« Reply #2 on: Wed, 23 April 2014, 13:15:13 »
http://geekhack.org/index.php?topic=56253.0
There's an artisan selling custom 60% keyboard bags. Round 2 should be open soon.
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #4 on: Wed, 23 April 2014, 13:51:26 »
This one looks pretty cool! :)
Offline intelli78
« Reply #5 on: Wed, 23 April 2014, 21:35:26 »
Indeed -- tomorrow, in fact.  :)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #6 on: Wed, 23 April 2014, 22:03:35 »
I have one of the EK hhkb bags, it's pretty solid design-wise and not terrible looking.
Offline minho
  • i'm kind of back
« Reply #7 on: Wed, 23 April 2014, 22:10:10 »
Does the HHKB have the same dimensions as a standard 60% (specifically, the Poker)
also, how is the room for the cable in that case?
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #8 on: Wed, 23 April 2014, 22:16:04 »
If anything, it might be a hair wider than mx 60% boards.
I can fit like 10 cables in the front pocket easy.  I'm planning on using it to carry my stuff to keycon.
Offline esoomenona
  • Gnillort?
« Reply #9 on: Thu, 24 April 2014, 06:10:35 »
I put my cable right behind my keyboard in the main pocket, then put my RF23UB and MX Revolution in the front pocket.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #10 on: Thu, 24 April 2014, 07:53:46 »
Another option is the VISM Range Bag Insert by NcSTAR. The padding along the sides isn't that great, but it fits anything from an HHKB up to a Duck Poker. It's very inexpensive and I've bought a couple.
That being said, I'm looking to get one of intelli78's bags in round 2. I think it offers better protection.
