Author Topic: Temporary labels for blank keycaps  (Read 9291 times)
Offline Koggiri
« on: Thu, 24 April 2014, 13:43:43 »
Hello  :) I recently bought a blank HHKB pro 2, and I'm having trouble using the number row.
I don't have a problem with the rest of the keys, but I have never touch typed the number row before and I'm having trouble getting used to it (especially the ones near the right pinky). What would be the best way to temporarily write/tape/glue something onto the keycap until I get used to it?
Offline pbtforever
Re: Temporary labels for blank keycaps
« Reply #1 on: Thu, 24 April 2014, 15:09:59 »
Blue Paint masking tape.
« Reply #2 on: Thu, 24 April 2014, 16:20:48 »
Don't use blue tape.
Labels actually exist, although not for your specific purpose. They're made for tween girls to trick out their laptop keyboards.
Offline ekw808
  • Ekw
« Reply #3 on: Thu, 24 April 2014, 16:26:52 »
Use a different colored key for 1 and 0, and work off of that.
[One Keyboard at a time]
« Reply #4 on: Thu, 24 April 2014, 20:43:26 »
Welcome to Geekhack!
I'd try two layers of sticky tape and a Sharpie.
Write the legends on the first layer, then stick another layer over the top so you don't rub them off.
Probably make the tape long enough to wrap under the sides of the keycaps.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Fri, 25 April 2014, 14:55:18 »
I suggest waterslide decals, and put them on the front side not the top. You can get waterslide paper that works in inkjet/laser printer and can make the labels in any font or color your printer can do. They can look as nice as a manufactured product, and they can last a pretty long time as side print even without a clear coat, and are easy enough to remove when you don't want them there anymore.
If you have white caps, you could use dry transfers instead. You can find them in many different font styles and sizes. They are also easy to apply and remove. As with waterslides they are not super durable so side placement is also advised there.
Offline mason
  • have fun with her, ryan
« Reply #6 on: Fri, 25 April 2014, 17:40:56 »
What ekw808 said. I put one on 1, 5, 0.
Offline Koggiri
« Reply #7 on: Sat, 26 April 2014, 00:38:49 »
Thanks for the suggestions!
I put a little piece of masking tape on numbers 1 and 0, it's helping me immensely.  :thumb:
Offline mickyman
« Reply #8 on: Fri, 02 May 2014, 15:12:07 »
I did that, it was cool
Poker II /w blues         Ergodox /w blues
Offline aref
« Reply #9 on: Fri, 02 May 2014, 17:28:15 »
There are many key-cap decals on ebay for about $18 a set. They are sold in different colors. Here's one listing:
http://www.ebay.com/itm/Mechanical-Keyboard-Cherry-MX-Keycap-Key-cap-Vinyl-Decals-023-/171129093175?pt=PCA_Mice_Trackballs&hash=item27d816bc37
Offline James35
« Reply #10 on: Thu, 15 May 2014, 23:52:37 »
That's actually kind of cool. IvanIvanovich, I like your suggestion on the front of the keys instead of the top side.
