Author Topic: Genius Mechanical vs Thermaltake Poseidon thoughts ??  (Read 3942 times)
Offline davkol
  •  Post Editing Timeout
Re: Genius Mechanical vs Thermaltake Poseidon thoughts ??
« Reply #1 on: Fri, 25 April 2014, 10:08:41 »
Genius Blue LED Illuminated Backlit Mechanical Laptop PC Gaming Keyboard 104 Key
Key Switch: CHERRY Blue
Switch life: 10 Million Times
This is suspicious at best. Tt are at least honest about their use of fake MX (Kailh).
That being said, I'd avoid any of that crap.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Fri, 25 April 2014, 12:54:16 »
Ya neither are really good.  There are better choices out there.
If you can tell us about what you look for in a keyboard also your budget and location then we can help you better.
Though so far based on your choices I'm going to guess that you want a MX Blue backlit minimalist looking full size keyboard am I correct?
In that case I'd probably recommend Ducky or Max Keyboard.
Offline da20valve
« Reply #3 on: Fri, 25 April 2014, 22:10:11 »
What do you mean by fake MX ?? (its says switch type Cherry blue)
and yeah I'm after a blue or the ever illusive green switches backlit mechanical 104 key keyboard.
PS I really like how the keys are risen (not inlayed into the keyboard).
« Last Edit: Fri, 25 April 2014, 22:21:50 by da20valve »
Offline FoxWolf1
  • 154
« Reply #4 on: Fri, 25 April 2014, 23:01:04 »
Maybe the ad says that. But there are pictures of the keyboard that show the switches...
Hint: look at what it says on the switch housing.
Hint #2: it ain't "Cherry."
Also, p.s., if you like backlighting, you might be a bit disappointed in the Genius. Only 8 keys (WASD and the arrows) are backlit. The others just have shiny letters-- no LED, just colored to look like it's lit up.
« Last Edit: Fri, 25 April 2014, 23:04:17 by FoxWolf1 »
Offline davkol
« Reply #5 on: Sat, 26 April 2014, 01:09:27 »
http://geekhack.org/index.php?topic=56406
Offline da20valve
« Reply #6 on: Sat, 26 April 2014, 02:07:55 »
So "fake MX" is just a term used to describe non cherry MX switches ??.
What do you guys think about this then, I wish it had the rased up keys like the Genius/
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=401
Are these "REAL" switches
Offline IronJoeJac
« Reply #7 on: Sat, 26 April 2014, 12:36:34 »
It quite clearly states that they are cherry switches, it even provides a animation of the switch with a large cherry logo on.
CM Quickfire TK (blue)    HHKB PRO 2 Black
Offline karazi
« Reply #8 on: Sat, 26 April 2014, 20:22:17 »
Cherry's patent on MX switches expired earlier this year so there are now clones available.  Some companies call the clones "certified mechanical switches," so I'd be wary of a keyboard that does not specifically say "Cherry MX" if you are looking for such.  The brown version of Thermaltake's Poseidon keyboard has Cherry switches while the blues are certified non-Cherry switches.  I have the Poseidon with browns and I really like it.  I got it for the backlighting mainly, as I already have two other non-backlit boards with browns.  No complaints except perhaps for a slightly louder ping noise than my other boards when bottoming out/switch release.  Fn media shortcuts and adjustable backlighting are pluses otherwise it is standard-issue.
« Last Edit: Sat, 26 April 2014, 20:24:02 by karazi »
Offline da20valve
« Reply #9 on: Sun, 27 April 2014, 00:29:53 »
Thanks but I am not interested in anything but Blue or Green, as for the switches used on the Genius they are the same as used in the Razor Black Widow Ultimate, I think now there is a lot of people saying these aren't as good and so forth which is understandable with any clone or replica that's new to the market.
