Author Topic: Good mice for claw gripping?  (Read 8382 times)
Offline poisened_blueberry
« on: Fri, 25 April 2014, 20:05:53 »
Basically the title. Although i'd like to avoid razer mice as i've already got 2 of them(deathadder and abyssus).
Offline neunelfer
  • HHKB Pro
Re: Good mice for claw gripping?
« Reply #1 on: Fri, 25 April 2014, 20:40:32 »
Zowie FK
« Reply #2 on: Fri, 25 April 2014, 21:30:09 »
Cooler Master Storm Spawn.   I has a fantastic sensor in it (one of the few "flawless" ones on ESR), is dirt cheap, and, oddly, is comfortable for just about every grip out there.
« Reply #3 on: Sat, 26 April 2014, 08:24:49 »
What are your thoughts on zowie ec2 evo?
Offline munch
« Reply #4 on: Sat, 26 April 2014, 10:39:52 »
it's fantastic, and works fairly well for claw grip for me. I don't claw grip but I have tried it with the EC2 eVo. can't say if it's ideal but I have a bit larger hands som claw gripping it wasn't a problem for me at least.
Offline Candyflip
« Reply #5 on: Sat, 26 April 2014, 10:58:34 »
As a claw grip user I would recommend the mico if you have small to medium sized hands. I don't know anything about sensors and stuff but the shape of the mouse is good kinda similar to abyssus.
« Reply #6 on: Sat, 26 April 2014, 11:14:35 »
Anyone have experience with fk and ec2 evo?
Offline munch
« Reply #7 on: Sat, 26 April 2014, 11:23:36 »
yes to both, yes both work with claw grip. just depends on how clawy you want to be and how large your hands are. :P
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #8 on: Sun, 27 April 2014, 12:52:59 »
Avior 7000
Offline MsYutai
« Reply #9 on: Mon, 28 April 2014, 11:01:22 »
Steelseries Kana v2 is another good option.
CM Storm Quickfire XT - MX Reds
Roccat Kone Pure Optical|Kana v2|Zowie FK|Logitech g500s|Mionix Naos 7000|CM Spawn|Logitech Performance MX
« Reply #10 on: Fri, 09 May 2014, 13:40:02 »
Oooooohhhhh the fk feels good, major upgrade over the abyssus. My only quirk with it is the coating, not really sweat friendly.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #11 on: Fri, 09 May 2014, 14:48:04 »
These mice always had a good claw grip.
This is bunny
(\__/) This is Bunny. Copy and paste Bunny into your
 (='.'=) signature to help him gain world domination!
 (")_(")
Offline feizor
« Reply #12 on: Fri, 09 May 2014, 17:00:47 »
I have used the cm spawn for about 2 years. Its works well and is cheap but its very short, so my wrist is always sitting on the mouse pad. This can get uncomfortable after a while. I have been using a zowie fk for the last week. It's very comfortable. The only issue is the mouse wheel is a bit stiff. And it's about twice the price of the cm spawn. My fk is not the new 2014 version with the black base which has a new wheel design. But apparently the 2014 version has an issue with coating peeling.
« Reply #13 on: Fri, 09 May 2014, 17:18:09 »
The wheel on the 2014 version is great, not stiff at all.
Offline davkol
  •  Post Editing Timeout
« Reply #14 on: Fri, 09 May 2014, 17:30:52 »
Depends on what you consider stiff. For me, most wheels other than the one on xornet/spawn or old MS mice feel too stiff; it's more tolerable only when it's very wide and rubbery. My middle finger is somewhat malformed though.
Offline Blackehart
« Reply #15 on: Fri, 09 May 2014, 18:53:35 »
I have about 15 mice in a tub.
The two i always fall back on are the spawn xornet and http://www.gx-gaming.com/?action=products_detail&wtype=feature&id=16
I LOVE the GX's finger buttons. My one gripe with the naga was that activating the side buttons would always make me move the mouse, not so with the GX.
Offline Novus
  • Mondai nothing~
« Reply #16 on: Fri, 09 May 2014, 19:03:23 »
That is until you experiment on them!
Offline slickmamba
« Reply #17 on: Sun, 11 May 2014, 03:19:43 »
I have pretty big hands and I claw grip the ec1, it works well
Hi :)
« Reply #18 on: Thu, 05 June 2014, 19:56:55 »
ROCCAT Kone Pure! You're Welcome!
Offline missalaire
  • Great Finder of Great Finds
« Reply #19 on: Thu, 05 June 2014, 20:40:55 »
Just got a Logitech G502 and I like it so far. I have small hands.
Offline CK Briefs
  • formerly calvins1
« Reply #20 on: Thu, 05 June 2014, 20:48:54 »
The length of the buttons are pretty huge, so your finger doesn't rest at the tip of the button, right?
I don't feel like the mouse is my size if my finger isn't hitting the edge :P
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline missalaire
« Reply #21 on: Thu, 05 June 2014, 21:13:44 »
Holding it normally, my thumb just rests at the edge of the sniper button and I don't have any issues accidentally hitting it even though I have it unassigned.
Offline HipsterPunks
  • Gangnamember
« Reply #22 on: Thu, 05 June 2014, 21:48:42 »
i have been doing some window shopping for a new claw grip mouse to replace my Rat 7, thank you for putting this mouse on my radar. I'm really feeling the design and i have an inkling my RAT is going to die on me very soon (dat laser eye getting stuck) I noticed you are replacing your g9x is that due to unhappiness with the mouse or simply looking for something new? The g9x was going to be my next pick up.
sell ass and eat out
Offline CK Briefs
  • formerly calvins1
« Reply #23 on: Thu, 05 June 2014, 21:51:32 »
I meant that if my index and middle finger don't reach somewhere near the edge of the LMB and RMB, I find the mouse to be too large
But that's just me :P
Offline missalaire
« Reply #24 on: Thu, 05 June 2014, 22:30:47 »
I was very happy with my G9x, but I've been looking for Logitech to come out with a G9x successor ever since I learned they discounted the G9x and wanted to try something new. I've been reading reviews and comments from people who got the G502 and it has gotten generally very good reviews and many people find it useable for a claw grip or mixed claw/palm grip so I figured I'd give it a try.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #25 on: Thu, 05 June 2014, 23:00:39 »
You won't be disappointed at all with this model.  Still love using it in almost any way possible on my mouse matt.  It's quite versatile in the way you can hold this model that is quite different with previous G500 range.
Plus it's sensor is way good compared to anything ever released by Avago Corp  :thumb: .
Offline missalaire
« Reply #26 on: Thu, 05 June 2014, 23:18:25 »
Ah I see. My fingers don't reach anywhere near the edge of the LMB or RMB but its k. I'm really liking the way it feels in my hand and I'm glad the hump of the palm area isn't ridiculously high. I tried a Corsair M65 a while back and the palm hump was way too obtrusive for me.
Offline quaddragon
« Reply #27 on: Thu, 05 June 2014, 23:44:44 »
I know you said that you wanted to avoid Razer mice since you had 2 of them.
However if you would consider looking at one. I would suggest the Razer Orochi.
It's Razer's laptop sized mouse quite a bit smaller than any of there full size mice.
It's about the same size as the Logitech VX Nano. I've owned both. I don't have big
hands by any means. Medium size I would guess. I used them both with a claw type grip.
Offline feizor
« Reply #28 on: Fri, 06 June 2014, 00:33:59 »
Will be picking up a roccat kone pure optical this weekend. Will post my thoughts  on it.
« Reply #29 on: Fri, 06 June 2014, 01:46:51 »
Good choice! I wish they made the orange in Optical.
