Author Topic: have I broken this matrix  (Read 2536 times)
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« on: Sun, 27 April 2014, 06:18:20 »
I started soldering this up last night, but I realised this morning I don't think I have soldered the diodes correctly, I have accidentally soldered before each switch diode - here is pic:
Do I need to take this apart and start it again?
I got boards.
Offline OldDataHands
Re: have I broken this matrix
« Reply #1 on: Sun, 27 April 2014, 13:00:01 »
Yes.
  • Dungeon Dweller
  • Get back to work!
« Reply #2 on: Sun, 27 April 2014, 16:46:55 »
Yes.
I'd figured as much :P
That's what happens doing stuff when tired, I looked at it this morning and just thought, bahhh that's all wrong! thanks :)
I got boards.
Offline jacobolus
« Reply #3 on: Mon, 28 April 2014, 00:39:24 »
The usual way to do things is to have the diode between the switch and the column/row. But I知 not 100% convinced that your way won稚 work. You値l be routing the current through a bunch more diodes than necessary, but I think they might still serve to isolate switches so you avoid ghosting.
  • Dungeon Dweller
  • Get back to work!
« Reply #4 on: Mon, 28 April 2014, 02:57:29 »
It's no bother - only took me an hour and a bit to do that bit - won't take me long to take it all off and start again, I have thousands of diodes so that's no thing! Will start it again sometime this week.
I got boards.
« Reply #5 on: Mon, 28 April 2014, 09:16:05 »
The voltage dropped across each diode renders this circuit useless...
Offline jacobolus
« Reply #6 on: Tue, 29 April 2014, 05:34:15 »
Oh, right. :-) If the voltage drops half a volt or something for each diode, then 10 in a row is definitely not going to work out. :-) Re-wire away!
