Author Topic: [Aesthetics] What's a good moogle set for BSP classic beige PBT on a Poker?  (Read 3312 times)
Offline intelli78
Since BSP doesn't have 1.25x molds, this set only comes in winkeyless format.
If I were going to put it on a standard keyboard (a Poker), I'd need to fill in the 7 1.25 modifiers on the bottom row. RGB is a nice choice, imo, but most RGB sets don't come with enough 1.25 keys or the proper legends.
So I put the question to you guys, how would you fill out the mods with this set? Just looking for some cool ideas!
Offline IvanIvanovich
  • Mr. Silk Underwear
I think imsto Cherry font dyesub Cherry profile KBC keys is your only good choice to have some consistency in looks and feel. If you can stand having some lasered keys pulling them from a G80-3000/8000 series with PBTs would be the next best choice. If you can tolerate mix material then go with some Cherry/GMK doubleshots.
Offline Lastpilot
  • Power stance
I have GMK Olivetti doubleshots mixed with BSP blank winkeys and they match perfectly!
So if you have the money, you can try getting a Black on White/Beige GMK set. :]
Offline Heezy
  • Formerly trynds
Did the BSP blank winkeys came from the beige set?
Rig - i3 6300, 240GB SSD, 500GB SSD, Gigabyte H170N Wifi, 16GB DDR4, Zotac 1060 Mini, 650w SuperFlower
Monitor - HKC144hz Mouse/Mousepad/Keyboard - Zowie EC1A - Zowie GS-R - Zowie Camade - Filco TKL MX Pink
IMSTO mods will have off color caps lock though, right?
Yes, imstos have white fulltouch caps lock. Maybe you should get a GH60 instead of the Poker and you can use the set as is... a better plan!
