Author Topic: Building my Custom Keyboard (FaceW, FMJ #2, etc)  (Read 17029 times)
Offline HPE1000
  • Keycap Paparazzo
« on: Mon, 28 April 2014, 08:51:47 »
This will be a build log for my keyboard. I had been wanting to do this for months and I can finally start, I have been getting parts for it since October last year. The PCB and Plate are in the mail and should get here today or tomorrow and I will start assembly shortly after.
Keyboard "specs"
-Cherry MX Clears (67g Limited Springs, Lime Green Switch Stickers, Krytox Lubricant, Transparent Switch Tops)
-GMK Classic Beige Doubleshot Keycaps
-FMJ Design #2 Grey
-Sprits "FaceW" 60% PCB (Black)
-5mm Acrylic Plate
-Green LEDs
-Cherry PCB Mount Stabilizers (Clipped and Lubricated)
This will be my first real custom keyboard, and the first keyboard I fully solder. I am soldering the Diodes, Resistors, Switches, and LEDs.
Here are some pictures of the parts going in this keyboard.
« Last Edit: Wed, 30 April 2014, 00:55:09 by HPE1000 »
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
Re: Building my Custom Keyboard (FaceW, FMJ #2, etc)
« Reply #1 on: Mon, 28 April 2014, 11:58:52 »
Loving this! Can't wait to get some updates! :) :)
Very busy with studies atm.
Offline b7ad
  • ゆめうつつ
    • mechblog
« Reply #2 on: Mon, 28 April 2014, 12:00:58 »
Look forward to updates. Those transparent switch tops look great!
« Reply #3 on: Mon, 28 April 2014, 12:02:14 »
Is that screw there just to hold down the drawer liner or do you just have it threaded in there for safe keeping? Nice pictures too :)
Offline HPE1000
  • Keycap Paparazzo
« Reply #4 on: Mon, 28 April 2014, 12:41:00 »
What screw?  :confused:
« Reply #5 on: Mon, 28 April 2014, 12:44:19 »
Looks like there's a screw center right in the case holding in the drawer liner? Close to the right edge.
« Reply #6 on: Mon, 28 April 2014, 12:45:59 »
Isn't that just the stand-off in the bottom of the case?
« Reply #7 on: Mon, 28 April 2014, 12:47:39 »
C'mon CPT, step it up. You should've known that was a standoff for the PCB.
« Last Edit: Mon, 28 April 2014, 12:50:48 by Photekq »
« Reply #8 on: Mon, 28 April 2014, 12:49:15 »
C'mon CPT, step it up. You should've known that was a standoff.
Which is why I asked if it was a screw or it was just a placeholder for something else. Was kinda hoping to see something different in a case design.
Offline HPE1000
  • Keycap Paparazzo
« Reply #9 on: Mon, 28 April 2014, 13:28:21 »
Nope they are just standoffs.
Well, it is technically together (no leds or led resistors installed though) I have some problems. Lots of keys aren't registering and I don't know if I messed up some soldering(diodes) or what, so I am just going to wait to see if sprit has any advice. (this could all by my fault, first time putting together a keyboard in this fashion)
« Reply #10 on: Mon, 28 April 2014, 13:31:43 »
If you have a multimeter handy, you can check to see if your solder joints are ok by running a continuity check.
Offline HPE1000
  • Keycap Paparazzo
« Reply #11 on: Mon, 28 April 2014, 13:33:25 »
I don't. I mean, I am wondering what it could be because it seems so consistent (maybe not the right word) how the whole bottom row isn't working then the little stripe up the side.
« Reply #12 on: Mon, 28 April 2014, 13:35:35 »
Maybe you can take a pic to show us the solder joints? That might be a little faster than waiting for sprit's reply?
« Reply #13 on: Mon, 28 April 2014, 13:37:13 »
Probably a couple diodes installed backwards, or maybe the firmware isn't programmed correctly?
Offline HPE1000
  • Keycap Paparazzo
« Reply #14 on: Mon, 28 April 2014, 13:38:47 »
I was thinking one of the two, I will flip diodes later today to see.
Offline HPE1000
  • Keycap Paparazzo
« Reply #15 on: Mon, 28 April 2014, 13:39:38 »
Okay lol
My solder joints are great I think, pics incoming.
Offline HPE1000
  • Keycap Paparazzo
« Reply #16 on: Mon, 28 April 2014, 13:46:09 »
Working Keys
Non Working Keys (Bottom Row)
« Reply #17 on: Mon, 28 April 2014, 13:47:24 »
Hm...your joints look ok so I think jdcarpe's got the right idea.
Offline HPE1000
  • Keycap Paparazzo
« Reply #18 on: Mon, 28 April 2014, 13:48:31 »
Well I have got about 20 mins here before I have to go run off and do something, so I will flip a couple diodes and see what happens.
Edit: Flipping them didn't work :(
Maybe I should get some through hole diodes and see if that would work.
« Last Edit: Mon, 28 April 2014, 13:59:55 by HPE1000 »
Offline Jokrik
« Reply #19 on: Mon, 28 April 2014, 15:05:11 »
Hope you find the problem soon
You are building a beast as I can see,  well done
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #20 on: Wed, 30 April 2014, 00:43:02 »
It has fixed!  Thanks! HPE1000   :thumb:
The PCB I sent to HPE1000 was an early hand soldering sample from a factory.  I did not like it, no more samples with them.
We found a cold soldering issue on the MCU, retouched several pins, fixed it.
I am doing soldering, checking and inspecting all the PCBs to ship.   ;)
« Last Edit: Wed, 30 April 2014, 01:00:43 by sprit »
Offline exitfire401
  • The Force is Re/\l
« Reply #21 on: Wed, 30 April 2014, 00:55:22 »
Those stickers look great, and your solder joints look good as well. Good job so far, buddy!
Offline HPE1000
  • Keycap Paparazzo
« Reply #22 on: Wed, 30 April 2014, 01:05:28 »
Thank you, it is my dream keyboard :)
Correct, everything is working now.
Thank you, I just put on the resistors and I am working on getting all the leds in right now. It is 2 AM currently though lol
Offline exitfire401
« Reply #23 on: Wed, 30 April 2014, 01:09:32 »
[/quote]
Been there haha. Soldering is the easy part though. De-soldering everything on my race took multiple days while soldering took an afternoon. (also helps that all of the SMD components were already soldered.)
Offline HPE1000
  • Keycap Paparazzo
« Reply #24 on: Wed, 30 April 2014, 01:14:29 »
True that, desoldering isn't fun at all. I just put LEDS in my poker 2 last night, those stupid presoldered pads over the led holes are annoying.
Offline exitfire401
« Reply #25 on: Wed, 30 April 2014, 01:16:02 »
That can actually be dealt with pretty easily. Just apply heat to the pads, and push the led through from the other side. No de-soldering required =) At least, that's what I did on my friend's poker.
Offline sprit
« Reply #26 on: Wed, 30 April 2014, 01:36:20 »
Great Job!!!   :thumb:     Thanks for Your TIP!
No desoldering is same as what I do, when I put LEDs on the pre-soldered (lead covered) pads in PCBs like Pokers.
- place a LED to the position, heat up positive pad, let the positive LED leg pass thru the pad a little bit. (till the shorter leg touch it's pad)
- Heat both pads to let the both Legs pass all thru, and check all.
« Last Edit: Wed, 30 April 2014, 01:42:27 by sprit »
Offline exitfire401
« Reply #27 on: Wed, 30 April 2014, 01:41:06 »
No desoldering is exactly what I do, when I put LEDs on the pre-soldered (lead covered) pads in PCBs like Pokers.
- Heat both pad to let the both Legs pass all thru,  check it.    That's all.
Yup, and then touch up the pad with a little bit of extra solder to make sure the joint is completely filled.
Offline sprit
« Reply #28 on: Wed, 30 April 2014, 01:46:51 »
:thumb:    Yes Sir!  My  Maestro!!
Offline exitfire401
« Reply #29 on: Wed, 30 April 2014, 01:48:36 »
I am but a mere peon compared to the likes of you sir, haha.
Offline HPE1000
  • Keycap Paparazzo
« Reply #30 on: Wed, 30 April 2014, 02:07:19 »
It's done :)
Offline exitfire401
Offline HPE1000
  • Keycap Paparazzo
« Reply #32 on: Wed, 30 April 2014, 02:17:42 »
I will post more pics tomorrow, it is 3:20 AM but yeahhh  :))
Offline exitfire401
« Reply #33 on: Wed, 30 April 2014, 02:21:47 »
Looks great! Congrats on the awesome board, and yeah, I don't blame you at all. Go get some sleep...I'd do the same, but I'm working until 7am.
Offline HPE1000
  • Keycap Paparazzo
« Reply #34 on: Wed, 30 April 2014, 02:41:58 »
Thanks :D
I am typing this message with the new keyboard. It is SO SO SO silent, this is actually amazing how quiet this thing is. @________________@
Terrible picture, but I am done, 3:40
Offline exitfire401
« Reply #35 on: Wed, 30 April 2014, 02:48:47 »
Thanks :D
Looks awesome. And I agree, clears are so spectacularly silent. I've actually been rotating my race 2 in with my alu skin for after the fiancee goes to bed since I finished it because it feels amazing and is almost quieter than my vintage blacks.
Offline Lain1911
  • God of the Wired
« Reply #36 on: Wed, 30 April 2014, 02:50:47 »
yummy sour apple.
Offline n0rvig
« Reply #37 on: Wed, 30 April 2014, 02:52:14 »
That's such a beauty! Great job HPE1000. I love the green LEDs & stickers.
Offline HPE1000
  • Keycap Paparazzo
« Reply #38 on: Wed, 30 April 2014, 08:11:33 »
Offline n2k
  • plasticchair
    • donate skins pls
« Reply #39 on: Wed, 30 April 2014, 11:26:58 »
So so sexy :eek:
Good work!  :thumb:
« Reply #40 on: Wed, 30 April 2014, 11:27:41 »
Slick as hell. Nice one :thumb:
« Reply #41 on: Wed, 30 April 2014, 11:30:39 »
Thanks :D
I'd love to see that wich dolch on it :D
Offline pmh1410
« Reply #42 on: Wed, 30 April 2014, 11:52:42 »
Hi HPE, I'm curiour about keymap with FaceU PCB. Can you guide me and everybody to keymap this PCB? Thanks in advance ;)
Offline HPE1000
  • Keycap Paparazzo
« Reply #43 on: Wed, 30 April 2014, 12:05:32 »
I think I will try it soon, I have flashed the firmware already and that was super easy.
Here is a little guide sprit made for it, seems simple enough. He did say he would be working on a more in depth guide soon though.
http://geekhack.org/index.php?topic=50580.msg1256970#msg1256970
Thanks, I am so happy to have it done.
So so sexy :eek:
Good work!  :thumb:
Thanks :D
I would too, hopefully dolch will available soon from ivan.
Offline CK Briefs
  • formerly calvins1
« Reply #44 on: Wed, 30 April 2014, 12:12:25 »
Awesome custom, HPE!
I think I'm more obsessed with the quality of the PCB than the board itself hurhur
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline HPE1000
  • Keycap Paparazzo
« Reply #45 on: Wed, 30 April 2014, 12:21:51 »
Here is a little sound comparison.
Stock poker 2, WASD keycaps, MX Black switches.
https://soundcloud.com/user343835333/poker-2-mx-blacks-430
Face W, Cherry keycaps, MX Clear switches.
https://soundcloud.com/user343835333/face-w-clears
It's so nice to listen to.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #46 on: Wed, 30 April 2014, 12:22:19 »
Looks great ! I really can't wait to receive mine.
Offline Jokrik
« Reply #47 on: Thu, 01 May 2014, 01:44:47 »
Well done!
That looks amazing,  I know how you went through all the troubles to collect all the parts.  And to see it assembled, I can't even imagine your satisfaction
Thumbs up
Offline sprit
« Reply #48 on: Thu, 01 May 2014, 22:11:13 »
Stock poker 2, WASD keycaps, MX Black switches.     -  No Mod?
Face W, Cherry keycaps, MX Clear switches.   - Lubed?
What makes the difference?  I am interested  ;)
If You have chance, Would You please put the Face +Clear SW +5mm Acrylic Plate combo to the Poker2 case, and compare both, vice versa?
Offline HPE1000
  • Keycap Paparazzo
« Reply #49 on: Thu, 01 May 2014, 22:16:07 »
I will do that tomorrow, as I am now interested to find out.
I have a feeling it is a combination of everything, the thick metal case, shelf liner, acrylic plate, and non clicky switches that make this keyboard so quiet.  ;)
