Author Topic: CM Storm Spawn for $13.99 after rebate  (Read 1757 times)
Offline Shyfe
« on: Mon, 28 April 2014, 13:54:10 »
This is definitely the best mouse you can get at this price if the shape is right for you. It uses the same sensor found in more expensive mice.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826570012
HHKB (55g) | IBM SSK | Realforce 87U (55g) | Unicomp EnduraPro | KBT Oni
Offline epzy
  • HHKB Fiend
  • ded
Re: CM Storm Spawn for $13.99 after rebate
« Reply #1 on: Mon, 28 April 2014, 14:34:53 »
Wow, insanely good deal.
« Reply #2 on: Mon, 28 April 2014, 20:54:05 »
might pick up a spare.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #3 on: Mon, 28 April 2014, 20:55:42 »
I really hate mail in rebates  ::)
Otherwise I would totally pick one up in a second (even though I'm quite taken with the Zowie stuff)
Offline codyeatworld
« Reply #4 on: Mon, 28 April 2014, 20:57:38 »
been using this mouse for a few months, its not bad at all, just a bit small. I think I paid ~$25 for mine.
Offline SnareSpectre
« Reply #5 on: Wed, 30 April 2014, 08:13:26 »
Just my two cents, but I would personally recommend against this mouse. It takes a LOT of getting used to the shape, and I found the "ring finger" rest area to be awkward instead of ergonomic. The clicking also feels...sloppy to me. It's not well defined like in every other mouse I've used - I found myself clicking when I didn't want to a LOT. Got mine for $25 and honestly still didn't think it was worth it.
I'm with jwaz - after going through several mice I laid my hands on a Zowie FK and will likely never switch again.
