Author Topic: HELP! noob pulled off model F big ass enter key and can't put it back in place  (Read 6253 times)
Offline Janeiac
What's a noob to do? Advice much appreciated, especially with pictures .I've studied all the teardowns on here and youtube fo hours, and I still can't see what I need to do.
Offline intelli78
You just have to position the stabilizer wire relative to the clips built into the case, such that when you push the Enter down to reseat it, the wire will slide into the clips. I don't know if that will help you if you've already studied the teardowns, but it shouldn't be that difficult. Where exactly are you going wrong? Are you having trouble getting the wire to go in the clips?
Offline Janeiac
Thanks for answering. I see two little tabs above the right-hand shift key... how does the wire fit? are they open at the top, or bottom? Even with my eyeglasses on I can't tell. Do I finger-feel the wire towards the shift key?
They probably open top. With an ISO Enter, I think that they face sideways.
I use a very small screwdriver to guide them into place.
- D Trump 2026-10-24
Offline intelli78
I don't have my AT F with me at the moment, but if memory serves, the clips open at the top. So you need to position the wire against the steel plate, so that as you push it down onto the stem, the wire slides toward you and under the clips.
Edit: One trick I use is to get the stem lined up with the spring, and then tilt the enter away from you. Then use some type of thin implement to hold the wire down on the plate so that it guides into the clips.
Offline Janeiac
Success! Thanks for the advice, intelli78's description was just what I needed. See y'all in my next thread! :)
