Author Topic: Standalone trackpoint to put into custom keyboard  (Read 4738 times)
Offline cool-RR
« on: Mon, 28 April 2014, 16:03:14 »
Hi everybody!
I'm building a custom keyboard. I'm considering putting a trackpoint in it. Is there a company that sells trackpoints standalone, rather than in a complete keyboard?
Thanks for your help,
Ram.
Offline plainbriny
Re: Standalone trackpoint to put into custom keyboard
« Reply #1 on: Wed, 30 April 2014, 21:35:18 »
I think you can get one from a used thinkpad keyboard, it would be much cheaper.
I got one with less than $5, a luck find.
Of course if you need a large volume, you can order from the manufacture, sprintex maybe?
http://sprintek.com/products/sk8702.aspx
Offline cool-RR
« Reply #2 on: Thu, 01 May 2014, 05:46:45 »
Thanks plainbriny! Buying wholesale is what I'm looking for.
Do you think that the Sprintek is the best choice? If you're familiar with other good manufacturers for tracking sticks, please send them all my way.
Offline plainbriny
« Reply #3 on: Thu, 01 May 2014, 06:58:31 »
Ten years ago, Elan announced that they developed a trackpoint compatible module, but I don't think that's still in their product portfolio now.
http://www.emc.com.tw/eng/index.asp
You can make queries if you need a large enough volume.
There's another thread discussing the sources of trackpoint modules and the possibility of group buy
http://geekhack.org/index.php?topic=57531.0
Offline cool-RR
« Reply #4 on: Fri, 02 May 2014, 10:28:12 »
