Author Topic: HHKB Layout for emacs  (Read 4447 times)
Offline Busty
« on: Thu, 16 April 2009, 14:51:16 »
Hi,
I started using emacs again for R (Ess), LaTeX (AucTeX) and fell in love with org-mode. The HHKB seems like really made for this. So, what are your experiences using an HHKB with emacs?
Offline sje
« Reply #1 on: Tue, 21 April 2009, 10:43:06 »
hi Busty,
I've had a HHKB (lite) for nearly 8 years now, and have loved using it with Emacs.  It does work very well with emacs I think.  Glad to hear that you are an ESS user - I'm one of the developers, and indeed my HHKB was used for almost all my elisp coding for ESS.
Just recently I found this forum as my HHKB lite was starting to play up, and I've been looking for a replacement -- they are no longer sold in Europe.  I was thinking of getting a pro, but the new realforce sounds intriguing.
Also, whilst searching for keyboard advice, I was surprised to read that the old MIT keyboards (on which presumably emacs was developed in the early days), has the ctrl and meta keys around the spacebar.  I've always just used the ctrl key to the left of A, and used diamond as the meta key, and stayed well clear of the alt key.  But it looks like in the old days, the key closest to the space bar was ctrl, and then meta was the next key out:
http://www.johnbear.net/symbolics-keyboard-paper/gnu-emacs-kbd-for-mac3.html
I've never tried this arrangement on the HHKB, but would be curious to know if others had.
Offline Busty
« Reply #2 on: Tue, 21 April 2009, 12:40:10 »
ESS is great once you get the hang of managing the buffers. I still didn't figure out a comfortable way to enter data in tables without using excel, though.
On the Model Ms I got Meta in the Alt key next to the space bar, Ctrl on Caps and the keys in the corners as Super/Apple/Windows.
Yesterday I ordered an HHKB Pro on Ebay from "stlensbar". Several others here had a good experience with him, and he is really fast in responding to questions.
