Author Topic: How is your KMAC/custom TKL Fn layer programmed?  (Read 2865 times)
Offline intelli78
« on: Mon, 28 April 2014, 23:24:58 »
I just got my first programmable TKL (WANG Saver  :p) and I'm learning how to use the Flip software.
For 60% layouts, I generally set up HHKB shortcuts for the Fn layer. But with this TKL, I'm drawing a blank on useful ways to use the Fn layer.
That's not necessarily a problem, of course! But I'm still curious to know: have you guys found a useful way to use your TKL fn layers?
Offline Pacifist
  • on hiatus
Re: How is your KMAC/custom TKL Fn layer programmed?
« Reply #1 on: Mon, 28 April 2014, 23:30:54 »
for a tkl, you don't really need any layers. Maybe some for media control and an imbedded numpad, but thats pretty much it
Offline intelli78
« Reply #2 on: Mon, 28 April 2014, 23:31:41 »
That's pretty much my conclusion as well, just wondering if there are any super clever ideas out there.
« Reply #3 on: Mon, 28 April 2014, 23:52:33 »
I don't really use it much on my KMAC.  Just put the numpad keys on the number row.
You could solder a MX lock on for the Fn key then make the Fn layer a COLEMAK layout.  That would be cool.
Offline intelli78
« Reply #4 on: Tue, 29 April 2014, 00:58:28 »
Not a bad idea at all. Do you happen to know how to handle an MX lock switch w/ the XML markup?
« Reply #5 on: Tue, 29 April 2014, 12:08:00 »
I have no idea how to deal with KMAC XML.  It has been a long time since I used that software.  Once I ported my firmware to the KMAC, I never looked back.
However, the reason I mentioned a MX Lock is that I didn't think that KMAC had a toggled Fn key, but I may have been wrong about that.  In any case, you shouldn't have to put anything about the specific switches in your software description.  I don't know why you would need to describe that.
« Reply #6 on: Tue, 29 April 2014, 12:09:29 »
Metalliqaz, does your Easy AVR support an MX Lock switch?
« Reply #7 on: Tue, 29 April 2014, 12:14:54 »
Firmware support not required.  All the MX Lock does is simulate holding the switch down.
Say you had two layouts, one normal and one on the Fn layer.  If all you have available is a regular old momentary Fn key, then you would need a Lock switch to keep the Fn layer active while you type.  If you have a Fn key that works as a toggle, or is software lockable, then normal switches would be just fine.  Easy AVR USB supports all kinds of Fn modes.  (momentary, toggle, lockable)
« Reply #8 on: Tue, 29 April 2014, 12:16:09 »
Ah that's good to know. I thought I had read elsewhere that locking switches needed firmware support. TIL :D
Offline intelli78
« Reply #9 on: Tue, 29 April 2014, 12:19:20 »
Yes, thanks for the info! MX Lock is definitely cooler than a Fn toggle, but the trick is finding one for sale.
« Reply #10 on: Tue, 29 April 2014, 12:20:29 »
They do if you want to use them for Caps or Num lock.  I have a "locking caps" code in my firmware that handles a MX lock on the caps lock key.  It sends a caps press on the down stroke and another one on the upstroke.
Offline zeroni13
« Reply #11 on: Tue, 29 April 2014, 15:42:29 »
Here is my layers for my TKL Phantom keyboard.
https://drive.google.com/file/d/0B0Hi55n4CaCKdjMydWdwcFlmcXc
Media keys are the same as on a BlackWidow which was my previous keyboard, and i just added mouse control for fun really.
« Last Edit: Tue, 29 April 2014, 15:47:35 by zeroni13 »
Phantom with Silver Vortex Case   Keychron Q6 Pro ISO Knob
« Reply #12 on: Tue, 29 April 2014, 15:46:09 »
I haven't got a programmable board, but if I did I'd program it exactly like a Filco.
I like Filco layout a lot.
