Author Topic: Interchanging springs in Model M or Unicomp  (Read 2145 times)
Offline zig_ziglar
« on: Tue, 29 April 2014, 21:57:12 »
Has anyone experimented with this? Are there aftermarket springs of varying resistances available like there are for MX switches?
My searching and googling has not helped so far :(
Cheers
Re: Interchanging springs in Model M or Unicomp
« Reply #1 on: Tue, 29 April 2014, 23:09:01 »
AFAIK the Unicomp spring assembly is compatible with the Model M spring assembly.
Thus I would anticipate the reverse is also true.
Based on having seen somewhere here a recommendation that someone purchase springs from Unicomp to refurbish a Model M.
Offline zig_ziglar
« Reply #2 on: Tue, 29 April 2014, 23:11:46 »
Thanks for the reply. Has anyone other than Unicomp produced springs for model Ms that are of different tensions? I'm just wondering about converting one to a softer actuation force (purely an experiment).
Offline Hyde
  • White Tofu Extraordinaire
« Reply #3 on: Tue, 29 April 2014, 23:12:25 »
I think it would be cool if people sell aftermarket spring with different stiffness for buckling spring.
Since some people find buckling spring too heavy and model F's weight is just right.  So it would be cool if there are lighter spring to mimic model F's weight. (even though they're mechanically different)
Offline JPG
  • Model F is my new passion!
« Reply #4 on: Tue, 29 April 2014, 23:15:55 »
I am absolutely no expert, but as far as I know, the lighter spring on the model F is possible because there is no contact thx to the capacitive aspect of it. The model M needs more energy from the spring in order to press on the pcb with enough for to actuate the switch. At least, that's how I understand it :)
Offline zig_ziglar
« Reply #5 on: Tue, 29 April 2014, 23:41:51 »
Sounds like a lighter spring alone would not be sufficient then. Probably requires a complete overhaul/redesign of the mechanism.
« Reply #6 on: Tue, 29 April 2014, 23:55:19 »
so the buckling spring design, I think isn't conducive to spring weight changes like it is for cherry MX.
« Reply #7 on: Wed, 30 April 2014, 07:06:12 »
You are probably right, but I would love to have lighter springs, even if they were only a little lighter.
"As I fear not a child with a weapon he cannot lift, I will never fear the mind of  a man who does not think."
"Never argue with a stupid person. He will drag you down to his level, and win through experience."
- Franklin Roosevelt 1933
« Reply #8 on: Wed, 30 April 2014, 07:11:46 »
I have used spring hammers from various models. I think that they are all the same, outside of manufacturing tolerances which are hard to predict.
There is an unproven consensus that old springs get "tired" over time, but I am not sure that I buy it. I have bought several M-122s and have a couple of jars full of springs that are 2+ decades old but have probably seen little use and are probably as good as new.
My "pride and joy" M is a 1390131 with a set of Unicomp springs from just a few years ago and a white latex Unicomp mat (aka blanket).
