Author Topic: $500 mouse!  (Read 12497 times)
Offline karlito
    • http://altitudegame.com
Offline ozar
$500 mouse!
« Reply #1 on: Thu, 16 April 2009, 20:15:58 »
Ouch!  It's highly doubtful that I'd ever spend $500 on a mouse.
Offline FKSSR
$500 mouse!
« Reply #2 on: Thu, 16 April 2009, 20:33:23 »
That seems like it's more of a "media controller" than just a mouse, but it's till essspensive.
Add me on Steam | Twitter
Offline D-EJ915
$500 mouse!
« Reply #3 on: Thu, 16 April 2009, 20:42:39 »
It's a 3D controller, not a mouse...stupid person who wrote the article.  Been around forever too, used to be called Spaceballs and were originally made by Labtec (amazingly enough lol)
Offline zwmalone
$500 mouse!
« Reply #4 on: Thu, 16 April 2009, 21:03:32 »
which is owned by logitech.  3dConnexion is also owned by logitech, although it's much higher quality brand.  Who would buy a $500 mouse from labtec (crap brand) when they could buy it from 3dConnexion who specializes in 3d navigation utilities...
Can't get enough of them ALPS
Offline o2dazone
$500 mouse!
« Reply #5 on: Thu, 16 April 2009, 22:27:45 »
Yeah, along with my G15 keyboard, I can keep my eyes off the screen even more now!
Offline extaleR
$500 mouse!
« Reply #6 on: Fri, 17 April 2009, 03:35:53 »
hi,
my first post here :)
look here: http://www.99hk.biz/Microsoft_IMO_1.1se.htm
nearly 600USD :D extremly sought after by (professional) fps-gamers
Offline FKSSR
$500 mouse!
« Reply #7 on: Fri, 17 April 2009, 06:32:21 »
Hi.  Welcome to GeekHack!
I am going to be getting a MS 1.1 mouse soon, but it won't be one with such inflation...
Offline extaleR
$500 mouse!
« Reply #8 on: Fri, 17 April 2009, 08:47:46 »
Quote from: FKSSR;86132
thank you very much :)
yeah, imo1.1 se is very sought after because of it's glossy surface which gives very good control while the surface of imo1.1 is a little bit "grainy" :) but it's the only difference between this two. hf with the imo1.1. nice mouse (i own two of them :)
Offline FKSSR
$500 mouse!
« Reply #9 on: Fri, 17 April 2009, 09:13:52 »
Another member here said he didn't like the grit-type surface of the regular 1.1, but I'm not sure I would dislike it.  I would have to try it to make sure, though.  I probably will be buying one in the next week.  It's been "on my list" for a while now.
Thanks for the input!
Offline extaleR
$500 mouse!
« Reply #10 on: Fri, 17 April 2009, 10:27:18 »
Quote from: FKSSR;86157
yeah, for some users its an issue :| but give it a try :)
is you want to save a little bit money you can buy IMO1.1a. This is the OEM version of the regular one, only without drivers, box and guarantee. you can find the drivers on the microsoft-homepage if needed.
back to the surface: if you don't like it, you can mod it :) here a link:
http://hardware.gotfrag.com/portal/forums/thread/395489/
btw.: IME 3.0 has the same optical sensor as the IMO1.1 if you like it more :)
Offline FKSSR
$500 mouse!
« Reply #11 on: Fri, 17 April 2009, 10:35:43 »
So, is the difference between the 1.1 and 3.0 just the shape?
Offline extaleR
$500 mouse!
« Reply #12 on: Fri, 17 April 2009, 10:40:25 »
Quote from: FKSSR;86171
Yeah, just the shape. If you want it cheaper you can even get the Wheelmouse Optical 1.1 (WMO1.1). It has the same optical sensor too :)
« Last Edit: Fri, 17 April 2009, 10:50:13 by extaleR »
Offline D-EJ915
$500 mouse!
« Reply #13 on: Fri, 17 April 2009, 11:45:08 »
I've got one of those optical intellimouse things...nice ambidextrous mouse
Offline Eclairz
$500 mouse!
« Reply #14 on: Fri, 17 April 2009, 16:13:56 »
yep they've been around for a while and always carry a hefty price tag. this ones more expensive because its larger has a screen even more buttons.
They are used as Media Creation/Editting Tools, like all work flow tools you have to get used to them. It is 3D due to the twist forward back ward motions you can do with them, a puck like flight stick as it were. They are more precise and due to the numerous controls they can be used to create different effects.
Lenovo ThinkPad TrackPoint Keyboard
RealForce 45g UK 88UB
FILCO Majestouch TenKeyPad
Offline Shmak
$500 mouse!
« Reply #15 on: Tue, 21 April 2009, 13:42:34 »
This is a 3D design tool for use with programs like Maya, 3D studio, Lightwave, CAD, and Softimage. It is also used with the left (or non-mouse) hand to rotate and maneuver the camera in 3D while the mouse hand is used to select and manipulate polygons etc.
Its basically to cut down the "double duty" of the mouse in these programs, since the mouse manipulates the camera (normally with a mod key like ctrl) and then after positioning it is used to paint or select.
I guess when your job is to produce 3D models and environments quickly in an industry like games or post production, every second counts. But for the average user this thing is not even an option.
Offline o2dazone
$500 mouse!
« Reply #16 on: Tue, 21 April 2009, 15:31:24 »
I'm a motion graphics artist by occupation, and a doorknob with a couple buttons is pretty much all I need that would be considered 'extra equipment'. I couldn't imagine putting anything important on that screen that would require me to look down so often. The article did get circled around work a bit, but no one really had anything to say about it.
Offline lowpoly
$500 mouse!
« Reply #17 on: Tue, 21 April 2009, 16:34:59 »
(Almost) the first 3D software I worked with was Superscape VRT. It came with the original SpaceMouse. The SpaceMouse was really well integrated. You could move, rotate, scale objects by just using the regular mouse. They would align and connect automatically if moved. Because of that you could leave your left hand on the SpaceMouse for longer periods.
In Maya for ex. you have to hit the keyboard with the left hand to switch between move/rotate/scale. It's easier to leave the hand on the keyboard for viewport changes then.
Offline watduzhkstand4
$500 mouse!
« Reply #18 on: Fri, 22 May 2009, 01:15:20 »
wow what the fack?! that mouse must be too complicated to use just because it has so many features.
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline lowpoly
$500 mouse!
« Reply #19 on: Mon, 07 September 2009, 08:28:54 »
Offline InSanCen
$500 mouse!
« Reply #20 on: Mon, 07 September 2009, 16:46:54 »
It's Toms Hardware "reviewing" it... They're idiots.
Most "serious" websites reference Tom's with a roll-eyes.
In GH terms, it's MX switches. Tehcnically correct (Mechanical), but fairly crap in general.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline lal
$500 mouse!
« Reply #21 on: Tue, 08 September 2009, 10:48:47 »
Quote from: InSanCen;115585
Err, you surely meant XM, not MX, right?
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline InSanCen
$500 mouse!
« Reply #22 on: Tue, 08 September 2009, 19:36:21 »
Quote from: lal;115736
I was tired, and had toothache... But yeah, I'm thick... Typo's on a Keyboard Forum... You'll be dragging me out and beating the soles of my feet soon.
I suspect the Logitech mouse a foot in front of me may have sneaked in there.
Offline lal
$500 mouse!
« Reply #23 on: Wed, 09 September 2009, 01:52:49 »
Beating your soles is the minimum punishment for calling MX "fairly crap"! Now, doing the same with XM is encouraged though :)
Offline InSanCen
$500 mouse!
« Reply #24 on: Wed, 09 September 2009, 02:05:18 »
Quote from: lal;116044
"Balky" Alps.
I still want a keyboard with some in, just to feel what a "balky" switch feels like. I suspect it will bring out the same feelings of rage that a Balky PC does when I am trying to fix it.
« Last Edit: Wed, 09 September 2009, 04:33:19 by InSanCen »
Offline Hak Foo
  • Make America Clicky Again!
$500 mouse!
« Reply #25 on: Thu, 10 September 2009, 10:22:43 »
Try fouling the keystems on a spare M.  It will get balky.
Overton130, Box Pale Blues.
$500 mouse!
« Reply #26 on: Thu, 10 September 2009, 10:28:33 »
Why did they make a mouse to complicated? That thing is just too much, I'm sure I won't be having fun gaming with it.
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline lowpoly
$500 mouse!
« Reply #27 on: Thu, 10 September 2009, 12:50:14 »
It's a 3D controller for CAD.
Offline InSanCen
$500 mouse!
« Reply #28 on: Thu, 10 September 2009, 12:51:17 »
Quote from: Hak Foo;116603
Heresy! Blasphemer!
Damage an M deliberately? Notabloodychance!
Offline Hak Foo
$500 mouse!
« Reply #29 on: Thu, 10 September 2009, 20:22:48 »
It may not be deliberate.  The right shift on my '90 1391401 had a bent shaft and it was balky, and I think dying my Customizer may have distorted a few keys.
$500 mouse!
« Reply #30 on: Thu, 10 September 2009, 21:37:25 »
Quote from: lowpoly;116681
is it really necessary? I use CAD and Solidworks fine with my mouse lol.
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline lowpoly
$500 mouse!
« Reply #31 on: Fri, 11 September 2009, 03:17:12 »
Quote from: watduzhkstand4;116849
Depends on the application. The support in animiation software was always lame so it doesn't help much there, if at all. Got my first space mouse with Superscape VRT (now defunct virtual reality software) and it was really well implemented. Left hand on the space mouse, right hand on the mouse for basic construction. With current animation software you have the left hand on the keyboard for shortcuts and the right hand on the mouse which makes it easier to do your viewport manipulations just with the mouse while the 3D controller would require to reposition the left hand.
Fun for fly-throughs though.
Quote from: ripster;116851
I suspect a dishwasher cleaning of the keys though.  Watch it with the heat on the larger keys especially.
Never had a problem with IBM keys.
