Author Topic: Howdy!  (Read 1477 times)
Offline bnadeau1
Howdy!
« on: Thu, 01 May 2014, 22:19:52 »
I'm new to the realm of mechanical keyboards, I just bought my first CM Storm Quickfire XT with Browns. So far I love it! The only thing I don't love is the font on the keys (it's a little over the top). I'm thinking about buying a new key cap set (maybe in white or grey) and I'm hoping I can find a good used set on here. I'm assuming since they are MX Cherry keys and the CM Storm quickfire seems like a popular keyboard, it should be pretty simple to find a full set (with tenkey) that will fit. However, any advice is greatly appreciated.
Thanks for your time!
EDIT:
Also, if anyone has experience changing out the LED's on the Num lock, Caps lock, and Scr lock, I'd be really interested in any advice you may have.
« Last Edit: Fri, 02 May 2014, 12:34:50 by bnadeau1 »
CMS Quickfire XT
Re: Howdy!
« Reply #1 on: Fri, 02 May 2014, 14:49:28 »
Hihi, sup son.
For your edit, all you really need to do is desolder the two pins on the LED and then put in the new one (the correct direction), and resolder them.
