Author Topic: Wireless Cherry MX Brown keyboard suggestions  (Read 2208 times)
Offline Jazermano
« on: Thu, 01 May 2014, 23:00:01 »
I've been trying to find a wireless Cherry MX Brown keyboard for ages, and I've gone in circles. The ones that are available turn out to be really bad and not mechanical, or they just don't have the customization potential I'm looking for. I just want a MX brown keyboard that is wireless, but I'd love it to have a colored back lighting (preferably blue). Honestly, I don't care what the color of the key caps are; I'll customize them later. Honestly, if anyone can recommend a keyboard or give me a link to a site that has a wireless cherry keyboard, I would be semi-eternally indebted.
Thanks for any replies/help!
          Jazermano (G33ks r kewl!)
Offline tbc
Re: Wireless Cherry MX Brown keyboard suggestions
« Reply #1 on: Thu, 01 May 2014, 23:14:37 »
filco minila air? plum 96?
let us know which size you're looking for
Offline Jazermano
« Reply #2 on: Thu, 01 May 2014, 23:36:26 »
I'm looking for more of a full-sized keyboard, because I want to use it in a build for a hybrid all-round+gaming computer. Basically it will just have better CPU and GPU and stuff.... but yeah full size plz! (I'm probably going to want to use this keyboard for a loooooong time, and use it on many computers, which is why customization is key to me here)
Offline ValerieV
« Reply #3 on: Fri, 02 May 2014, 17:04:36 »
KBTalking Pro. It's bluetooth.
Offline Jazermano
« Reply #4 on: Fri, 02 May 2014, 19:32:41 »
looks great, just what i'd like, but there's none of them to buy; it'll take AGES till i get it! I need one that i can ACTUALLY get... so any other recommendations? Also, I'm just wondering, are keyboards like the ducky shine 3 any good, or are they all market hype? I've seen the CODE keyboard and I kinda like it, because it's sleek and simple, and has a long enough cable so that i wont need the wireless. But, it doesnt have the backlighting i'd like, and i really wish the LEDs were color-customizable. So, if there is a keyboard similar to the CODE MX clear, but with more LED options, please let me know!
« Last Edit: Fri, 02 May 2014, 19:46:09 by Jazermano »
Offline tbc
« Reply #5 on: Fri, 02 May 2014, 21:46:01 »
ducly has pretty much every led color and switch combination.
it has detachable cable so you can swap in any length.
ducky is MORE than solid enough.
Offline Pacifist
  • on hiatus
« Reply #6 on: Fri, 02 May 2014, 21:57:23 »
get the $60 usb to bluetooth converter
Offline ValerieV
« Reply #7 on: Sat, 03 May 2014, 16:05:11 »
I love that thing. It has worked great for my IPAD! Well worth the money.     :thumb:
Offline Jazermano
« Reply #8 on: Tue, 06 May 2014, 17:06:25 »
sounds good, but where can i get it? can you give me a link please? Thanks!
