Author Topic: TIPRO (?) Keypad - Multipress >.>  (Read 1329 times)
Offline Jonny Chapman
« on: Fri, 02 May 2014, 01:58:18 »
Hi there,
Just wondering if anybody here has had experience with USB Keypads made by Tipro.
I have a KMX032A that I am trying to work with my PC/Mac for use with a few MMOs.
https://www.posmarket.com.au/products/Keyboards/Tipro-Free-Range/Tipro/KMX-032A_78658.html
The problem I am finding is that although all buttons are working perfectly, the signal on a key press only seems to transfer to my computer once, even when i hold down on the key.
Example; trying to run with the up arrow depressed does nothing, the same with backwards and turning left/right. When opening a document in say notepad, I can see that holding down any button on the device works once, and not multiple times. Holding down '5' creates a 5, but only once. Where the standard keyboard works as normal.
Anyways, just wondering if this is a limitation of the keypad, or is it something that I could working on with software/keyboard settings or even opening the device up?
Many thanks in advance.
Cheers,
Jonny
« Last Edit: Fri, 02 May 2014, 02:27:01 by Jonny Chapman »
Re: TIPRO (?) Keypad - Multipress >.>
« Reply #1 on: Sat, 03 May 2014, 19:42:08 »
Offline zulios
« Reply #2 on: Mon, 05 May 2014, 16:16:04 »
Well, you should try to have a look at your configuration in the tipro change me software.
There should be an option when you edit a key: repeat while pressed if I remember correctly. Make sure it is checked. I am using a tipro free matrix as my daily driver and never encountered such a problem.
Tipro matrix - mx black
