Author Topic: Unicomp 122 emulator black [Boscom]  (Read 6154 times)
Offline dw_junon
    • http://www.9999hp.net/
« on: Fri, 17 April 2009, 19:02:16 »
http://search.ebay.com/250403981147
$20 B-i-N, might be worth confirming the action.
I have no affiliation with the seller.
ARC/Chicony KB-5181 XT/AT blue ALPS? 101 US FCC ID E8H51KKB-5181 • AST ASTKB102 AT capacitive rubber dome 102 UK ISO
Cherry G80-2100 AT black Cherry 126 key German ISO unique • Compaq Enhanced III PS/2 unknown rubber dome 102 UK ISO
Datacomp DFK102ARA03 AT 102 blue ALPS? US/Arabic FCC ID blank, S/N 37880001 • Dell AT102W PS/2 Black ALPS 105 UK ISO x2
Fujitsu KFB4725-102 AT membrane rubber dome with spring 105 UK ISO • Hewlett Packard C1405A AT rubber dome 102 UK ISO
IBM 0989705 XT/AT no LEDs Model M 102 US/Arabic  • IBM 1388076 Industrial AT Model M 102 UK ISO
IBM 1389260 3179/3180 Display Station Model M 122 US 3270 x2 • IBM 1391406 PS/2 Model M 102 UK ISO x2
IBM 1397003 PS/2 Model M "Host Connect" emulator 122 German ISO • IBM 71G4643 PS/2 Model M Quiet Touch "Ouch!    Rubber spring" 102 UK ISO x2
IBM 5640987 3178 Display Station Model C2 capacitive buckling spring 87 key US 3270 • IBM 556-712-01 RT PC rubber dome [same as 2nd PCjr kbd?] 101 US
IBM 6450225 PC/AT capacitive buckling spring 84 key UK PC/AT • Lexmark 8125460 Model M2 102 UK ISO
NMB RT-102 117456-002 AT Hi-Tek black, clicky 102 UK ISO • Olivetti ANK 2462 M24 Personal Computer keyboard 2 clicky Olivetti spring module 102 UK unique
Ortek MCK-142Pro AT white ALPS 142 key UK • Sun 540-1006-03 Type unknown linear(?) keyswitch 2 87 key SunType2
Wang 724 725-3771-UK salmon ALPS 110 key UK Wang724 • Making this list hasn\'t half scared me...
[/I]
Offline D-EJ915
« Reply #1 on: Fri, 17 April 2009, 19:17:59 »
I asked them if it works with regular PCs or not...
Offline dw_junon
« Reply #2 on: Fri, 17 April 2009, 19:29:29 »
It has the LED panel and a purple plug, so I don't see why it wouldn't.  Shouldn't hurt to check, though.
[/I]
Offline D-EJ915
« Reply #3 on: Fri, 17 April 2009, 19:30:08 »
Hi d-ej915,
It does work with PCs.
-iNet
Offline dw_junon
« Reply #4 on: Fri, 17 April 2009, 19:42:35 »
That was quick.
Looking at that though, I'm guessing you didn't ask about the key action.
Not that I'm looking to buy it (won't ship outside US for starters)...
[/I]
Offline ozar
« Reply #5 on: Fri, 17 April 2009, 20:30:47 »
That thing looks like it might be huge, so you might have to get a bigger desk.
Offline D-EJ915
« Reply #6 on: Fri, 17 April 2009, 21:15:51 »
I went ahead and bought it...hope it does actually work with PCs...  Got $1.60 cashback ...
Offline ozar
« Reply #7 on: Sat, 18 April 2009, 08:45:35 »
Quote from: D-EJ915;86263
Congrats on the win/purchase!  Yes, please let us know how that works out with a PC.  I'm interested in knowing the size and weight of it too, if you don't mind sharing that information.
Offline D-EJ915
« Reply #8 on: Sat, 18 April 2009, 09:56:02 »
I'll give you a pretty good description of it, I'm interested in that info myself actually...I don't have a model m to compare it with though.
Offline dw_junon
« Reply #9 on: Sat, 18 April 2009, 10:33:41 »
Congrats!
From Letter #191-086:
Code: [Select]
PHYSICAL SPECIFICATIONS:
              Space Saving           Enhanced       [B]Host Connected[/B]
                Keyboard             Keyboard           [B]Keyboard[/B]
Width:       406 mm (16.0 in)     492 mm (19.4 in)  [B]532 mm (20.9 in)[/B]
Depth:       190 mm ( 7.5 in)     210 mm ( 8.3 in)  [B]215 mm ( 8.5 in)[/B]
Height:       58 mm ( 2.3 in)      58 mm ( 2.3 in)   [B]70 mm ( 2.8 in)[/B]
Weight:     1.90 kg ( 4.2 lb)    2.25 kg ( 5.0 lb) [B]2.32 kg ( 5.1 lb)[/B]
Unicomp production is likely to be the same size, but possibly not as heavy... AFAIK they don't publish such information though.
[/I]
Offline ozar
« Reply #10 on: Sat, 18 April 2009, 15:40:21 »
Thanks for the info, DW... that's not as big and heavy as I thought it might be, but it's still pretty massive.  :)
