Author Topic: PC Mic for Gaming (Linux)  (Read 2694 times)
Offline esko997
  • Linux Lover
« on: Fri, 02 May 2014, 23:34:56 »
Hey all,
I'm looking to get a microphone for my computer for use with Teamspeak and playing DoTA. I'm running Arch Linux and was wondering if anyone has any suggestions for microphones that work well with Linux? I'd imagine that as long as its a regular 3.5mm jack Linux shouldnt have a problem with it, but I've never had one before so I'm not sure.
Any help is appreciated.
Daily Drivers:  Unicomp Customizer (BS -- Linux Layout) | Vortex Race 3 (Clears)
Other Boards: CM Quickfire Stealth (Greens) | Poker II (Blues) | PLU-ML 87 (Ergo Clears)  | JD40 (Browns) | Leopold FC660C (Topre) | IBM Model M | ErgoDox (Clears) | Sentraq s60x DIY (Blacks) | Anne Pro 2 (Blues) | Cherry G80-11900 (Blacks) | Kira (99 Key) (Hako True)
Offline davkol
  •  Post Editing Timeout
Re: PC Mic for Gaming (Linux)
« Reply #1 on: Sat, 03 May 2014, 07:38:42 »
It's all about sound card support. yo!
Offline Zombly
  • Zombie Enthusiast
« Reply #2 on: Tue, 06 May 2014, 14:48:28 »
I honestly use a clip on zalman mic, I bought it for $5, it's beautiful, if you had a headset just clip it onto the wire and you're good to go, it's actually really high quality for such a cheap little microphone.
In the process of my custom Zombie board
[WTB MX Zombro's]
Offline esko997
  • Linux Lover
« Reply #3 on: Tue, 06 May 2014, 14:58:53 »
I ended up getting one of those Blue Snowball USB mics. Will reply to the thread tonight when I get home and let people know if I can get it setup/working.
Offline Zombly
  • Zombie Enthusiast
« Reply #4 on: Tue, 06 May 2014, 15:16:20 »
Curious about the quality as I was debating getting one of these, however $5 mic suckered me in.
[WTB MX Zombro's]
Offline esko997
  • Linux Lover
« Reply #5 on: Tue, 06 May 2014, 21:42:06 »
Hey so for those interested, the Blue Snowball Mic works great on my Arch Linux setup. Just plugged it in, turned it on in alsamixer, and bam -- working!
Offline Cottonsox
« Reply #6 on: Tue, 06 May 2014, 21:47:21 »
i use a modmic version 2.0,
Currently they are getting in their 4.0 and it looks like it is compatible with linux but might need abit more investigation, warning it is not a cheap option.
But the quality i have had from this mic is amazing, i use mine for gaming mostly league with friends and just general chatting. Since i have had it i have had no issue where multiple mics failed in the past.
Offline YummyTreeSap
« Reply #7 on: Wed, 07 May 2014, 01:07:33 »
The Blue Snowball is a pretty great little (well, big & unwieldy) mike.  The only real complaint I have with it is that mine is very very quiet, so I have to be all right up in it when I talk.  Of course, you generally should have a mike positioned right there in front of you, so it's not that bad as long as you have a pop filter.
