Author Topic: Buying Cherry stabilizers from Onlinecomponents.com  (Read 2402 times)
Offline StylinGreymon
  • Keyboard Hipstar
« on: Sat, 03 May 2014, 01:46:13 »
I'm trying to buy some stabilizers for the upcoming Duck Viper groupbuy, and have been told by several folks to get them here:http://www.onlinecomponents.com/suppliers/cherry-electrical-177/
But perhaps I'm blind, stupid, or some unfortunate combination of the two, because I can't seem to find them there.
Are they called something other than stabilizers?
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Buying Cherry stabilizers from Onlinecomponents.com
« Reply #1 on: Sat, 03 May 2014, 02:31:26 »
yah, what you want are the "leveling kits" from the MX datasheet
http://www.cherrycorp.com/english/switches/key/mx.htm
G99-07xxx is the pcb mount stabilizer part numbers. OLC has a reasonable number in stock right now. fallout from manufacturing politics.
  • Keyboard Hipstar
« Reply #2 on: Sat, 03 May 2014, 02:44:41 »
Alright, this is what comes up when I search for those part numbers:
63437-0
I've never sourced parts like this; am I going about it the wrong way?
Offline mkawa
« Reply #3 on: Sat, 03 May 2014, 07:36:05 »
yep, you're good. the 0g990742 part is for 2x-3x keys and the G990744 is for an 8x spacebar. that is the stabilizer wire is longer than you need for a 6.25 or 7x SB. you have to cut and rebend it with a duro-bro wire bender and a pair of leveraged cutters.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #4 on: Sat, 03 May 2014, 08:17:43 »
Well. We can buy PCB mounted & Plate mounted Stabilizer  :thumb: :thumb: :thumb:
Offline Latin00032
« Reply #5 on: Sat, 03 May 2014, 10:31:15 »
Since I'm looking for a viper, I'm going to need one out these, too.
Thanks for the heads up.
Offline Pacifist
  • on hiatus
« Reply #6 on: Sat, 03 May 2014, 10:46:32 »
Do they have MX locks too? And IMO best way to get PCB mounted stabs is buying old POS boards and selling the switches and keeping the stabs
Offline Latin00032
« Reply #7 on: Sat, 03 May 2014, 11:01:48 »
So the cherry website has plate mount stabs?
  • Keyboard Hipstar
« Reply #8 on: Sat, 03 May 2014, 14:24:44 »
Is that what we'd need for Viper?
