Author Topic: ANSI stepped enter key?  (Read 2372 times)
Offline user 18
« on: Sat, 03 May 2014, 12:06:17 »
Lots of people like stepped caps locks because (I assume) they don't want to hit it instead of the 'A'. I have a similar problem with hitting enter instead of ''' (yes I know that looks weird).
Does a stepped enter key exist, or is it not as good an idea as it sounds to me right now?
Avatar by ashdenej
Re: ANSI stepped enter key?
« Reply #1 on: Sat, 03 May 2014, 12:08:12 »
I've definitely never seen one of those on any keyboard.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #2 on: Sat, 03 May 2014, 12:34:06 »
I've seen some extremely old boards that way-- I think there are some PDFs of a early 80s Cherry catalog floating around with boards that way.
Overton130, Box Pale Blues.
Offline user 18
« Reply #4 on: Sat, 03 May 2014, 13:54:36 »
Something like that would work, although I was hoping for something just stepped on the left.
ANSI enter is 2.25x iirc, so something with just a 0.5x step on the left side and a 1.75x key would be what I'm looking for. If it doesn't exist that's fine, I need to learn to type properly anyway.
Avatar by ashdenej
