Author Topic: Got SP color rings? I need help trying to determine the PBT color for ABS WCK...  (Read 3153 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Any help would be greatly appreciated...
 ;D
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Someone has accurate pictures. I think it's mashby.
I can't seem to find it again, but I bet someone will link it.
WCX is probably the closest followed by WAS.
Offline 00zeRO
Are you physically looking at them right now? I order some other colors and they turned out to not be that close to the pictures, neither Mashby's nor SP's. I want to be sure...
Offline 00zeRO
I took them into the sun to compare. They're close, but there are no exact matches.
Offline 00zeRO
so, WCX is the closest?
