Author Topic: Are these PBT keycaps thick or thin?  (Read 9634 times)
Offline catcradle5
« on: Sat, 03 May 2014, 22:18:22 »
This is my first set of PBT keycaps and I'm not really sure how to judge the thickness. They are KBC brand.
Is there such a thing as "medium" thickness? I ask because I feel like I've seen pictures of keycaps that are thicker than these, and pictures of ones thinner than these.
« Last Edit: Sat, 03 May 2014, 22:22:48 by catcradle5 »
Offline Lu_e
Re: Are these PBT keycaps thick or thin?
« Reply #1 on: Sat, 03 May 2014, 22:33:31 »
Standard non-thick
Just say NO to ABS keycaps
Offline epzy
  • HHKB Fiend
  • ded
« Reply #2 on: Sat, 03 May 2014, 22:35:16 »
Yeah, yours are thin PBT.
Thick on the left, thin on the right.
Offline catcradle5
« Reply #3 on: Sat, 03 May 2014, 22:37:20 »
Standard non-thick
Thanks. They seemed to be advertised as thick... http://www.ebay.com/itm/37PBT-Plus-thick-Single-color-Key-caps-for-MX-Cherry-Switches-Side-printed-/300997693802
How do you know when a vendor is selling actual thick keycaps?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #4 on: Sat, 03 May 2014, 22:40:11 »
Standard non-thick
Buy from reputable people, or buy popular keycaps you know are thick.
"37PBT Plus thick Single color Key caps for MX Cherry Switches Side printed.
Six(6) Color option you can choose, High quality Caps"
Did you get six caps, where they thick? I think that's the ones he meant. The 37 PBT keycaps weren't thick, but the 6 other keycaps were?
Offline catcradle5
« Reply #5 on: Sat, 03 May 2014, 22:44:51 »
Standard non-thick
I believe he means six color options (blue, green, orange, yellow, etc.). I got all 37, and they all seem to be thin.
Offline jester_
« Reply #6 on: Sat, 03 May 2014, 22:45:51 »
Standard non-thick
That's saying they come in 6 colors.
OP, every PBT set on MechanicalKeyboards.com from vortex or Ducky is thick, except the blank black ones and the side printed black ones, they confirmed it over in their vendor forum
Offline Lu_e
« Reply #7 on: Sat, 03 May 2014, 22:51:22 »
Whoa thats my picture above haha... Random.
Just be sure they have a picture of the bottom before you buy. I wouldnt've expected qtan to screw you over like that honestly.
Offline catcradle5
« Reply #8 on: Sat, 03 May 2014, 22:53:23 »
Standard non-thick
So for example, these are definitely thick? http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=865
(Kind of funny that the Ebay listing specified as thick isn't thick, and the Vortex listings that don't specify thickness at all are thick.)
Offline catcradle5
« Reply #9 on: Sat, 03 May 2014, 22:54:25 »
I even made a post on reddit /r/mechanicalkeyboards before buying asking if qtan's thickness can be vouched for, and 2 people said the keycaps are indeed thick: http://www.reddit.com/r/MechanicalKeyboards/comments/23kgjt/can_anyone_vouch_for_qtans_keycaps/
Offline epzy
  • HHKB Fiend
  • ded
« Reply #10 on: Sat, 03 May 2014, 22:54:30 »
Standard non-thick
Ah, "Plus thick Single color Key caps", confusing as hell. :p
BSP keycaps are thick, GMK keycaps are thick, Cherry keycaps are thick, some Ducky keycaps are thick, Vortex keycaps are thick, IMSTO keycaps are thick - can't think of more right now.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #11 on: Sat, 03 May 2014, 22:55:42 »
Standard non-thick
Yeah, those are thick. That's the same keycaps that comes on Ducky Premier keyboards.
Offline Lu_e
« Reply #12 on: Sat, 03 May 2014, 22:58:26 »
Standard non-thick
Im still confused by that ebay listing. What is he using the term thick to describe exactly?
Also you cant just go by brand. I have thin vortex pbt for instance
Offline jester_
« Reply #13 on: Sat, 03 May 2014, 23:00:24 »
Standard non-thick
Yeah that's weird, I've heard good things about qtan as well, and those do seem to be "medium" thickness because I've seen some a bit thinner, but the recent Vortex sets (On MechanicalKeyboards) most definitely are nice and thick. This is my reddit thread regarding my new Vortex set: http://www.reddit.com/r/MechanicalKeyboards/comments/24nh8l/new_bicolor_pbt_keycaps_arrived_for_my_filco/
Offline epzy
  • HHKB Fiend
  • ded
« Reply #14 on: Sat, 03 May 2014, 23:01:16 »
Standard non-thick
Idk. They look thicker than WASD keycaps, but still they aren't thick.
Oh yeah? Which ones? I've only seen the doubleshot PBT keycaps from Vortex, 1st and 2ng gen and they are both thick.
Offline Lu_e
« Reply #15 on: Sat, 03 May 2014, 23:02:37 »
The early black legends on black keycap italic font pbt by vortex
Patiently waiting on ivans thick pbt groupbuy :]
Offline catcradle5
« Reply #16 on: Sat, 03 May 2014, 23:04:14 »
Standard non-thick
Yep, everyone I asked vouched for these.
Where/how did you order that Vortex set?
Nevermind, found it here: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=773
I'm also really interested in Ivan's keycap group buy, but since I missed the orders I'm going to either have to wait for someone to sell theirs or pick up a Vortex one probably.
« Last Edit: Sat, 03 May 2014, 23:06:44 by catcradle5 »
Offline Lu_e
« Reply #17 on: Sat, 03 May 2014, 23:06:03 »
The newer vortex 2shot thick pbt should be on MK in various colors
Offline jester_
« Reply #18 on: Sat, 03 May 2014, 23:08:54 »
Standard non-thick
Here, my dude
Offline lightsout714
« Reply #19 on: Sat, 03 May 2014, 23:10:36 »
That's weird qtan is a legit vendor. But I don't see anyway you could consider those thick. Maybe they are a bit thicker than the ones he used to sell?
Looking at the picture again nah those are totally thin.
Offline catcradle5
« Reply #20 on: Sat, 03 May 2014, 23:43:30 »
I think they're maybe thicker than Ducky's thin (or identical, difficult to tell), but thinner than Vortex's thick. I agree it definitely is not thick though.
I'm not sure if I misunderstood what "PBT Plus Thick" means, or if he's marked them up with an incorrect description.
Another shot, next to a quarter:
It's better than my ABS, so I guess I'll use these and wait a bit to see if I can get one of Ivan's blank sets (I prefer blank black over side-blue anyway).
« Last Edit: Sat, 03 May 2014, 23:52:46 by catcradle5 »
Offline Txduck
« Reply #21 on: Sun, 04 May 2014, 01:02:19 »
That's true, but these Vortex PBT double shot 2nd gen, caps are thick PBT. I have 2 sets of the blacks, but they have the same caps available in bi color blue/white and 2 or 3 other colors.
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=774
The left key cap below is the Vortex thick PBT double shot, the right key cap is a Ducky standard ABS cap.
This PBT doubleshot is approximately twice as thick as the ABS.
Click to enlarge the photo.
« Last Edit: Sun, 04 May 2014, 01:27:44 by Txduck »
Offline Txduck
« Last Edit: Sun, 04 May 2014, 01:24:34 by Txduck »
