Author Topic: Datalux Spacesaver  (Read 3732 times)
Offline maxtortheone
Datalux Spacesaver
« on: Sun, 04 May 2014, 15:07:26 »
Hello everyone, new here but found this rather interesting. Not sure on switches but still not bad considering they're new.
Link
Keyboards: IBM Model M 122 Key Terminal Board;  Logitech G710+; Focus FK-2001 w/ Complicated ALPS
Offline esko997
  • Linux Lover
Re: Datalux Spacesaver
« Reply #1 on: Sun, 04 May 2014, 15:12:35 »
Cool looking board, definitely interested in what switches are on there -- anyone seen this before?
Daily Drivers:  Unicomp Customizer (BS -- Linux Layout) | Vortex Race 3 (Clears)
Other Boards: CM Quickfire Stealth (Greens) | Poker II (Blues) | PLU-ML 87 (Ergo Clears)  | JD40 (Browns) | Leopold FC660C (Topre) | IBM Model M | ErgoDox (Clears) | Sentraq s60x DIY (Blacks) | Anne Pro 2 (Blues) | Cherry G80-11900 (Blacks) | Kira (99 Key) (Hako True)
Offline hoggy
  • * Ergonomics Moderator
« Reply #2 on: Sun, 04 May 2014, 15:12:37 »
Welcome to GH!
Mechanical, but not great to type on (can't remember, but I don't think mine's cherry).  Key spacing is pretty tight.  I'd pull mine out to check, but I think it's at the back of the cupboard.
Price is pretty good, though.
« Reply #3 on: Sun, 04 May 2014, 15:14:08 »
Deskthority says either MEI switch or Cherry ML.
Offline hoggy
« Reply #4 on: Sun, 04 May 2014, 15:22:50 »
Mine's MEI then.  I'd recommend getting the seller to pop off a cap and take pictures.  If they are willing, ask for the serial number and ask devlin if they could tell you anything about it.
« Reply #5 on: Sun, 04 May 2014, 15:26:49 »
CIDUC01 is the model but doesn't show up anywhere, info wise.
Offline vivalarevolución
« Reply #6 on: Sun, 04 May 2014, 16:37:57 »
I've seen that before.  I wonder how much you will accidentally hit the letter keys when using the keys on top.
« Reply #7 on: Sun, 04 May 2014, 17:12:43 »
That version is MEI: supposedly bad to type on.
Offline Wildcard
  • When caffeine isn't enough
« Reply #8 on: Thu, 08 May 2014, 23:57:51 »
Looks interesting, I think I have a datalux somewhere but it has bad rubber domes.
« Last Edit: Fri, 09 May 2014, 00:00:12 by Wildcard »
« Reply #9 on: Fri, 09 May 2014, 18:20:43 »
Are you sure it's not bad MEI switches?
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #10 on: Sat, 10 May 2014, 12:32:05 »
I cannot express enough how miserable MEI switches are.
Can. Not.
kishy.ca
Offline False_Dmitry_II
« Reply #11 on: Sun, 11 May 2014, 04:04:02 »
Can. Not.
Is it worse than the wet newspaper ones?
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #12 on: Sun, 11 May 2014, 18:43:31 »
I'm a little rusty on my keyswitch metaphors but I never used MLs if that's what you're referring to, so no comparison to be had.
Summing up my memory of MEIs...short travel, kinda high friction, unpleasant and unexpected bottom-out.
kishy.ca
« Reply #13 on: Sun, 11 May 2014, 22:37:13 »
ML's are pretty decent, in my opinion. I am sure he is referring to MY
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #14 on: Mon, 12 May 2014, 07:36:43 »
Right you are. It's been at least 2 years since I've read anything about either of them so it's all just a blur :)
But regardless, I remember MEI, and you don't want em.
kishy.ca
