Author Topic: Making another wooden wrist rest for a 'customer'  (Read 2760 times)
Offline tigersharkdude
« on: Sun, 04 May 2014, 21:22:28 »
A  buddy of mine contacted me about making a wrist rest for Quickfire TK. He opted for a custom green stain. This piece is slightly different than the original piece that I made, this one has a thinner base plate and the angle of the WR is not as sharp, thus causing the angle to more "natural" on your wrists
This is the color that Ed wanted, it's a custom green from Porter Paint
First step is cutting the pieces to length and gluing them together
After drying, it's now time to cut the initaial angle
After cutting the angle I then sand it smooth and get ready for stain
Testing it on my QFR (note the W.R. is NOT for a QFR)
after COUNTLES coats of stain we get this (this stain didn't soak well at all)
« Last Edit: Tue, 06 May 2014, 13:35:25 by tigersharkdude »
Re: Making another wooden wrist rest for a 'customer'
« Reply #1 on: Tue, 06 May 2014, 13:34:58 »
UPDATE: Polyurethane is on and I'll be wetsanding tomorrow
Offline Photoelectric
« Reply #2 on: Tue, 06 May 2014, 13:47:41 »
Thank you for sharing!  I like different-colored stains and actually got a shade very similar to the above years ago for a wood project that I never finished.  Pretty cool to see your work in progress.
« Reply #3 on: Tue, 06 May 2014, 14:11:50 »
thanks, I think it will look much better after I wetsand/polish and it gets a nice shine to it
« Reply #4 on: Tue, 06 May 2014, 17:54:11 »
UPDATE: Did the first wetsand/polish, and added another coat of poly for more protection
I am also working on an extra piece for a Poker II if anybody is interested in it
« Reply #5 on: Wed, 07 May 2014, 11:53:06 »
It is finished
« Reply #6 on: Wed, 07 May 2014, 11:53:39 »
 :thumb: :thumb:  Share more!
What is the reason behind attaching a bottom piece of wood to go under the keyboard?  It ends up raising the keyboard.  I usually find it more comfortable to have the keyboard as low as possible.
« Reply #7 on: Wed, 07 May 2014, 13:41:17 »
It raises the keyboard maybe 2mm (if that), and they are to keep your keyboard from sliding around (think about the pads on the bottom of dinning room chairs to keep them from sliding and from possibly scratching the floor)
« Reply #8 on: Wed, 07 May 2014, 14:00:29 »
2mm if that?  I see at least a centimeter and a half there, as seen from the side.  Also a lot of current mechanicals have some rubber pads underneath to help prevent sliding around.
« Reply #9 on: Wed, 07 May 2014, 15:02:20 »
EDIT 2: I totally misunderstood you, I thought you were referring to the anti-slip pads. The bottom plat is 1/2" (1.27cm) thick and the wrist rest is 3/4" (1.9cm) thick. The reason for the plate is to keep the keyboard in place with the wrist rest (to keep them together if that makes sense). If people were interested, I could try an even thinner piece of wood (1/4")(0.64cm) for the base plate
Quote from: DERP MOMENT
a centimeter? no, these things arent that big, they are dime/nickle sized in diameter
EDIT: just measured, ~2.5mm
« Last Edit: Wed, 07 May 2014, 15:14:17 by tigersharkdude »
