Author Topic: Keycaps for noppoo choco mini  (Read 2729 times)
Offline selist
« on: Mon, 05 May 2014, 14:06:13 »
So im a complete noob at modifying keyboards but i was interested in some bright white key caps after browsing the forums and wondering where i could get some to completely revamp my noppoo choco mini keyboard with red switches.
my keyboard exactly
http://www.amazon.com/Noppoo-Mechanical-Gaming-Keyboard-Switches/dp/B0091QOCNA/ref=sr_1_1?ie=UTF8&qid=1399316641&sr=8-1&keywords=noppo+choco+mini+red+switch
TL;DR - In need of some bright white key caps that will fit my keyboard!
Offline Lu_e
Re: Keycaps for noppoo choco mini
« Reply #1 on: Tue, 06 May 2014, 00:05:51 »
At a glance it has a small right shift... not sure how easy it is to replace caps on these.
Someone else will have to chime in...
Just say NO to ABS keycaps
« Reply #2 on: Tue, 06 May 2014, 00:13:41 »
The Choc Mini is a great keyboard but it can be very difficult to change out the caps.  Perhaps the most difficult is the space bar.  Looks like 5.5x maybe?  Very non-standard.
Offline Lain1911
  • God of the Wired
« Reply #3 on: Tue, 06 May 2014, 00:19:42 »
I don't own one but I have been looking into 75% boards and I've been told that the Choc mini spacebar is a pain to find. Right shift should also be the only other non-standard keycap.
Offline Oobly
« Reply #4 on: Tue, 06 May 2014, 04:18:43 »
Most sets with Tsangan kits will have everything you need except the spacebar. Mix of 1x and 1.5x modifiers, 1.75x right shift and a few extra 1x bottom row keys.
Dat space bar, though.... It is a 5.5x. Good luck.
You may just have to buy a white Choc Mini. Or better yet, a Keycool 84 which has a "normal" 6.25x spacebar, but almost identical character layout as the Choc Mini, including the embedded numpad. With that set you only need to worry about the 1.75x right shift (just like the KBT Pure I use).
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Defect
« Reply #5 on: Tue, 06 May 2014, 08:13:35 »
Only thing that came close to fitting a Choc mini spacebar is one I got off a TG3 Data911.   But it's also black, and I don't have the inserts to test.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Tue, 06 May 2014, 10:02:29 »
Cherry 1800 will get you most of the way. Keys are the same height as the stock ones too, so it won't feel awkward while you hunt down the 1.5 Ctrl and Alt from an older winkeyless Cherry model to match. You will be out of luck on the spacebar. Or... you could always try and get a trade on a set of white Choc mini caps.
Offline davkol
  •  Post Editing Timeout
« Reply #7 on: Thu, 08 May 2014, 08:05:11 »
What does "need" mean? The stock set is already one of the best in the market: thick Cherry-profile POM. If you want higher quality printing or light-colored keycaps for aesthetic reasons, consider Cherry dyesub alphas; they're quite durable too and have a matching profile. You could find even other key replacements, but spacebar width is unique (5.something indeed).
Unfortunately, white PBT choc mini appears to be EOL.
