Author Topic: Looking for LED compatable set.  (Read 1664 times)
Offline ShapelessJoint
« on: Tue, 06 May 2014, 02:33:03 »
Hello geeks,
I'm looking for a set of Key caps for my white backlit cherry MX keyboard.
I've seen a few sets made my ducky but they only come in "meh" colors like black, grey, and purple.
 If the keycaps cost more than $70 i would rather buy a another entry level mechanical keyboard instead. I'm looking for cheap sets, like the full sets available at elite keyboards, but translucent.
Do you know any place that might carry translucent keys?
-CM Storm Quickfire TK Cherry MX brown, Microsoft Sidewinder X4
Offline Oobly
Re: Looking for LED compatable set.
« Reply #1 on: Tue, 06 May 2014, 03:30:02 »
Translucent you say?
http://keyshop.pimpmykeyboard.com/product/clear-blank-full-104-keycap-sets
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=570
The Ducky caps are good. Great quality and they allow the backlighting through nicely. Not sure what colour you're after, really.
You can also use non-backlit caps, the light will still shine through most sets of thinner caps.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #2 on: Tue, 06 May 2014, 05:16:16 »
Meh colours like pink: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=711
There are very few proper backlit keycap sets that would suit a standard keyboard.  There are a few transparent/translucent keycap sets, but you can see the stems under the surface, and many people don't like that look.
« Reply #3 on: Tue, 06 May 2014, 11:40:59 »
Thank you for your replies. I have found the Ducky purples and pinks are the best deal... Although i also came across some really nice Limited edition toy series rainbow translucent keycaps, BUT I CANT BUY THEM ANYWHERE!
« Reply #4 on: Tue, 06 May 2014, 18:44:12 »
Those are by Niqmods, but their vendor forum was recently removed.
Offline Oobly
« Reply #5 on: Wed, 07 May 2014, 02:50:39 »
May be possible to make your own from the SP translucent set (the pimpmykeyboard link I posted before) the same way he did it. Make masks for each key, use car spray paint to paint the color on and then remove the masks and spray with clearcoat.
Or you could use the Max keyboard set which are kind of smokey grey semitranslucent and use different LED's for different colors: http://www.maxkeyboard.com/max-universal-black-translucent-mechanical-keyboard-keycap-set-top-print.html
See the last pic on that page.
