Author Topic: red scarf II 77测试版本  (Read 5341 times)
Offline 悬壶济世
red scarf II 77测试版本
« on: Wed, 07 May 2014, 07:44:37 »
red scarf II 77测试版,没想到这么快就找到了我的淘宝店,那我就把最近测试完的发上来吧,
另外我准备开发一个ISO版本的RS77,到时有GhostofHarry 在GH上开启团购,有兴趣的朋友可以关注一下
http://geekhack.org/index.php?topic=57948.msg1320228#msg1320228
Offline GhostofHarry
Re: red scarf II 77测试版本
« Reply #1 on: Wed, 07 May 2014, 07:49:55 »
感謝幫頂!
Thx for the support my friend :thumb:
appreciated it
lets make this happen
Offline rosslerosa
  • MF DOOM
« Reply #2 on: Sat, 17 May 2014, 15:37:39 »
Hi, I will be buying from your shop soon!
I just wanted to know how the programming of the keys will work, and if there are two Usb ports in the PCB since it is breakoff-able.
I can't really wait for the group buy and I will buy directly from you via a TaoBao agent.
Thanks for making such an awesome board! I can see a promising future for this PCB
