Author Topic: Post Pictures Of Your Desk/Set Ups!  (Read 2444818 times)
Offline Badwrench
  • ummmm.....I forgot
Re: Post Pictures Of Your Desk/Set Ups!
« Reply #3150 on: Thu, 06 November 2014, 14:12:15 »
Offline blackbox
« Reply #3151 on: Thu, 06 November 2014, 16:02:59 »
Nice! Which computer is your daily pc?
The LAN table!
Offline Badwrench
« Reply #3152 on: Thu, 06 November 2014, 18:01:16 »
There is only 1, the box in the corner is a foot rest, and the one to the left of that is my Energy Sub.
The Corsiar 250D on the left of the desk houses:
4670K
Asrock Z87 itx
Thermaltake Water 3.0 pro
660Ti w/ gtx 670 EVGA cooler and back plate (quieter and better cooling than stock Nvidia reference cooler)
8gb Samsung magic ram
1tb Samsung HDD
250gb Samsung EVO ssd
The case will be replaced in the near future with a Syrillian Acrylic test bench now that I have my own office and can keep the baby away.  I will be redoing the sleeving as well to go with the cable on my keyboard and the Toxic set.
« Reply #3153 on: Thu, 06 November 2014, 21:55:24 »
Hackintosh FTW!
Offline blackbox
« Reply #3154 on: Fri, 07 November 2014, 00:28:36 »
Hackintosh FTW!
How did you like building in the fortress ft03?
The LAN table!
Offline appleonama
  • Trollo en USA
« Reply #3155 on: Fri, 07 November 2014, 00:31:58 »
Offline blackbox
« Reply #3156 on: Fri, 07 November 2014, 00:42:28 »
4670K
Asrock Z87 itx
1tb Samsung HDD
I see, I though the footrest was a comuter case:). Why do you want to use a test bench?
The LAN table!
Offline blackbox
« Reply #3157 on: Fri, 07 November 2014, 00:47:02 »
Looks good, What kind of ssd(just guessing its ssd's) do you use in the raid 0 conf?
The LAN table!
Offline Badwrench
« Reply #3158 on: Fri, 07 November 2014, 00:48:13 »
4670K
Asrock Z87 itx
1tb Samsung HDD
Mostly because it was one of the last things that an acquatance from OCN that passed away from cancer a few years ago built.  It is beautiful and should be used rather than left in a box.
Offline blackbox
« Reply #3159 on: Fri, 07 November 2014, 00:49:42 »
4670K
Asrock Z87 itx
1tb Samsung HDD
I see. That makes sense. Look like a cool testbench!
The LAN table!
Offline Badwrench
« Reply #3160 on: Fri, 07 November 2014, 00:53:46 »
4670K
Asrock Z87 itx
1tb Samsung HDD
This is it:
Offline appleonama
  • Trollo en USA
« Reply #3161 on: Fri, 07 November 2014, 00:58:35 »
I use samsung evo 840
each 250gb
« Reply #3162 on: Fri, 07 November 2014, 08:52:38 »
Hackintosh FTW!
Well I decided to use a 770, 2 SSDs, a 3.5in HD, and an H60 so some case modding was required to mount it all. But the thermals are good and I love the look and size of the case. Overall it's a great case but you have to be a bit creative to make it work with everything.  :D
Offline blackbox
« Reply #3163 on: Fri, 07 November 2014, 09:51:34 »
Hackintosh FTW!
Well thats allot! What did you need to modify? Space for the H60?
The LAN table!
« Reply #3164 on: Fri, 07 November 2014, 09:53:54 »
How does that lamp not block your view??  :P
Nice setup!   :thumb:
Offline blackbox
« Reply #3165 on: Fri, 07 November 2014, 09:55:44 »
each 250gb
Nice. They are fantastic in my experience, I'm sure you feel the same.
The LAN table!
« Reply #3166 on: Fri, 07 November 2014, 10:38:38 »
Hackintosh FTW!
The FT03 mini only takes 10in graphics cards but the 770 is 10.5in so I had to cut part of the bottom bracket to make room. Also adding the H60 removed the place to mount the 3.5in drive so I drilled holes for that and the SSDs. All the modifications made the fan filter useless so I had to elongate it and drill a couple holes. Overall it was pretty easy it just required some tinkering to make it work and look nice.
Offline vyshane
« Reply #3167 on: Tue, 11 November 2014, 08:18:09 »
Home office :)
Offline blackbox
« Reply #3168 on: Tue, 11 November 2014, 08:29:11 »
Hackintosh FTW!
I see. thats a "few" modifications.  :)
The LAN table!
Offline heedpantsnow
  • Old enough to know better
« Reply #3169 on: Tue, 11 November 2014, 09:45:26 »
Home office :)
Wow, so clean, do you actually work there??
I'm back.
Offline ynrozturk
« Reply #3170 on: Tue, 11 November 2014, 10:06:02 »
Home office :)
Looks so clean and modern, love it.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline vyshane
« Reply #3171 on: Tue, 11 November 2014, 10:18:52 »
Home office :)
Yeah, I do quite a lot of work there. I keep a mostly paperless office. Most of my work lives in the cloud - in Git repos and the like.
Offline vyshane
« Reply #3172 on: Tue, 11 November 2014, 10:19:15 »
Home office :)
Thanks :) It's a work in progress.
« Reply #3173 on: Tue, 11 November 2014, 15:53:51 »
Home office :)
Very nice indeed :)
I'd be happy if my home "office" was half as neat as that!
« Reply #3174 on: Mon, 17 November 2014, 21:17:44 »
A little different:
Currently working at my sister's place in W Hollywood, CA.
I'm back.
Offline EvilOliv3
« Reply #3175 on: Mon, 17 November 2014, 21:56:51 »
Offline MGH
« Reply #3176 on: Mon, 17 November 2014, 22:37:34 »
Offline EvilOliv3
« Reply #3177 on: Mon, 17 November 2014, 23:19:27 »
What mousepad is that?
Razer Scarab. But I think they changed the name to Destructor 2 and it's black now.
Offline blackbox
« Reply #3178 on: Tue, 18 November 2014, 08:48:13 »
Nice! Whats that thing (kinda looks like a cog) next to your mosue?
The LAN table!
« Reply #3179 on: Tue, 18 November 2014, 15:16:13 »
I'm pretty sure it's like a magic 8 ball only you spin it for the answer. I don't know what it's called.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #3180 on: Tue, 18 November 2014, 16:35:31 »
 :( id have a geekhack worthy desk to share if it wasn't covered in empty beer bottles, cereal bowls, keyboard parts, trash, paperwork, some old hard drives, tools, etc etc etc etc etc etc
Offline redskull
« Reply #3181 on: Tue, 18 November 2014, 21:08:00 »
well that certainly sounds more than worthy Glod.  :D
Offline MGH
« Reply #3182 on: Tue, 18 November 2014, 21:58:08 »
That describes my desk too :))
Offline dryver
    • Reddit Profile
« Reply #3183 on: Tue, 18 November 2014, 22:18:05 »
Not a great camera, but here's my setup
Offline EvilOliv3
« Reply #3184 on: Tue, 18 November 2014, 22:24:54 »
lol that's exactly what it is. It's called a Natico Decision Maker / Paper weight.
I use it to make most of my purchasing decisions... but then sometimes I just keep spinning it until it says "yes", because I really really want to buy the item.
Offline blackbox
« Reply #3185 on: Wed, 19 November 2014, 01:34:31 »
ah, I see. keep spinning then.
The LAN table!
Offline appleonama
  • Trollo en USA
« Reply #3186 on: Wed, 19 November 2014, 01:45:43 »
Nice setup!   :thumb:
It does block my view quite a bit I been trying to find another lamp.
and thanks!
« Reply #3187 on: Wed, 19 November 2014, 01:47:01 »
My supervisor has one of those on her desk...the only problem is that I usually spin it and mentally ask inappropriate questions...or my supervisor asks something normal and the answer makes it weird.
Offline EvilOliv3
« Reply #3188 on: Wed, 19 November 2014, 03:43:13 »
upgrade that to a 40oz hydro flask, and you got yourself a good setup.
Offline SlotH42
  • one slow step for sloth
« Reply #3189 on: Wed, 19 November 2014, 08:25:41 »
MP-GBL4 (red) Poker II (clears) Realforce R2TL 55g
Offline blackbox
« Reply #3190 on: Wed, 19 November 2014, 09:09:41 »
Nice do you use that sys to switch between your headphones and your speakers?
The LAN table!
Offline oscillik
    • music podcasts
« Reply #3191 on: Wed, 19 November 2014, 12:53:04 »
ergodox is so useful....leaning up against the wall
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline SlotH42
« Reply #3192 on: Wed, 19 November 2014, 13:46:54 »
exactly. I just had to switch the input with output. Plugging in wires and unplugging them was too difficult for me :rolleyes:
Offline Altis
« Reply #3193 on: Wed, 19 November 2014, 22:18:42 »
A little different:
That there is how you use a tablet like a champ.
It's better than a laptop because when you're using it in public places, people won't think you're a nutcase for carrying/using a second keyboard.
The way you have it seems to work well. Surface Pro 3 + 60% mech board = closest thing to laptop with mechanical board.  :cool:
Offline kurukato
  • Cars>Keyboards
« Reply #3194 on: Thu, 20 November 2014, 01:29:12 »
Please excuse the mess. Thank HTC for the potato quality
Offline Gloomy Moonie
« Reply #3195 on: Thu, 20 November 2014, 18:20:48 »
Could you elaborate a bit on your audio setup?
I have a Q701 as well (waiting for me to unbox), and wondering about what DAC/amp combo should I go with. Currently debating between the O2/ODAC or the Magni/Modi.
Any advice/tips would be much appreciated.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #3196 on: Fri, 21 November 2014, 00:37:51 »
Keeping it simple on my desk right now. In that keep-as-little-in-front-of-me mood. I wish I had my Kensington Slimblade with me right now... I should also hook up my numpad 23UB to the HHKB... but I feel like it'll be too much clutter right now.
« Reply #3197 on: Fri, 21 November 2014, 10:24:32 »
Doo iiittt.  Then you can be like me!  ^.^
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #3198 on: Fri, 21 November 2014, 10:32:17 »
I think Hoff means like me (´・ω・`)
« Reply #3199 on: Fri, 21 November 2014, 10:38:12 »
 :-[  Yes, Senpai...
