Author Topic: Topre Realforce 87U and Scroll Lock  (Read 6854 times)
Offline qk6339zmdm
« on: Mon, 20 April 2009, 23:21:00 »
Got my 87U this weekend and like it very much (thanks stlensbar!)...
The only question I have is, how do you trigger Scroll Lock on it, for use with a KVM?  I tried the key by itself, with shift, control, shift-control, other combinations, with DIP switch 3 turned on and off to no avail...
« Last Edit: Tue, 21 April 2009, 08:54:18 by qk6339zmdm »
Offline skriefal
« Reply #1 on: Mon, 20 April 2009, 23:58:02 »
Scroll Lock = Shift + Num-Lock
Offline qk6339zmdm
« Reply #2 on: Tue, 21 April 2009, 08:53:53 »
Yep, shift+NumLock was the first thing I tried.  I think I'll swap out my KVM with one that has a hard switch, instead of just relying on a hotkey sequence.
Offline qk6339zmdm
« Reply #3 on: Tue, 21 April 2009, 21:53:47 »
Well, RTFM!  This saved me from buying a new KVM.  The IOGEAR GCS634U I'm using can be set to use Ctrl as a hot key instead of ScrlLk.
I wonder if Topre will fix this minor issue with a firmware update and DIP switch 4 will actually come in handy...
