Author Topic: Seeking Topre keyboard with volume control  (Read 3757 times)
Offline Renzhe
« on: Wed, 07 May 2014, 13:55:54 »
Hi. I've been using a Corsair K60 for a while and I like how there's a volume control wheel at the upper right. I recently received a Type Heaven and rather like the feel of it, but I miss the convenience of the volume control, as a lot of the time I am doing something fullscreen and don't want to go to the desktop, or I just don't want to touch the mouse and click on a little icon.
So, are there any Topre switch keyboards with a volume control of some sort? I prefer something like Corsair's implementation in their Cherry switch keyboards.
Alternatively, if anyone can tell me how to hack a volume control keyboard shortcut into Windows, that might also work.
Offline Dyslexic
  • All we love we leave behind
Re: Seeking Topre keyboard with volume control
« Reply #1 on: Wed, 07 May 2014, 13:57:22 »
There are no topre boards with dedicated media keys other than using the HHKB with Mac OS and drivers, as far as I'm aware. You can use autohotkey to create a key combination or assign a button to be "volume up/down", but in terms of a dedicated volume wheel I don't think you're going to find anything. It's the one thing I miss on my FC660C.
| HHKB Type-S | FC660C Silenced | ReΛlforce 23UB
« Reply #2 on: Wed, 07 May 2014, 13:58:57 »
You could use the mouse wheel up and down?
Or a USB control knob?
Offline esoomenona
  • Gnillort?
  • Live long and prosper
« Reply #4 on: Wed, 07 May 2014, 14:05:05 »
The NovaTouch will have volume controls on the Fn layer. But in your case, keyboard shortcuts will accomplish the same thing, without the need to buy another board.
tp thread is tp thread
Offline Renzhe
« Reply #5 on: Thu, 08 May 2014, 03:23:42 »
Thanks Dyslexic. I didn't know Autohotkey existed. I've got a script with
Code: [Select]
^F11::SoundSet -2
^F12::SoundSet +2
I kinda wish the changes were shown on screen though. And I ain't buying no $45 USB control knob. I ain't that crazy yet.
Offline atlas3686
  • HHKB Elite
« Reply #6 on: Thu, 08 May 2014, 03:36:54 »
Code: [Select]
^F11::SoundSet -2
^F12::SoundSet +2
If you run windows 8 volume changes are shown on screen by the OS, otherwise I think there are one or two programs that show volume on screen as its changed. Autohotkey is definitely the way to go.
« Last Edit: Thu, 08 May 2014, 08:55:40 by atlas3686 »
Offline Coreda
« Reply #7 on: Thu, 08 May 2014, 03:51:15 »
There's a neat app called 7+ Taskbar Tweaker that optionally adds volume control by scrolling on top of the taskbar (amongst many other great features).
The only volume related hotkey I use is for foobar2000. Usually keep the system volume the same.
