Author Topic: Does the 23UB send the correct key codes?  (Read 1281 times)
Offline daerid
    • Rossipedia
« on: Wed, 07 May 2014, 16:53:45 »
Or is it messed up (sending number row scan codes) like the Filco and Leo numpads?
Offline esoomenona
  • Gnillort?
Re: Does the 23UB send the correct key codes?
« Reply #1 on: Wed, 07 May 2014, 17:26:49 »
My 23UB sent correct scan codes.
Offline ComradeSniper
  • HHKB Pro
« Reply #2 on: Wed, 07 May 2014, 17:39:23 »
My 23u sends the correct scan codes.
Offline daerid
    • Rossipedia
« Reply #3 on: Wed, 07 May 2014, 18:31:21 »
Damn... now I want one even more. Thanks guys!
Offline Macsmasher
« Reply #4 on: Fri, 09 May 2014, 04:26:34 »
Yes daerid, I have one in white and it sends the correct key codes.
