Author Topic: How to reset pokerX custom keys?  (Read 1588 times)
Offline Jixr
« on: Wed, 07 May 2014, 18:02:59 »
Hi, I just bought a used PokerX, and I'm wondering how to reset it custom things assigned to it, and also how to turn the LEDS on the modifier keys on.
Thanks
Offline BlueBär
Re: How to reset pokerX custom keys?
« Reply #1 on: Wed, 07 May 2014, 18:47:33 »
The Poker X is not programmable so there is nothing to reset.
Check if the modifiers have LEDs? I don't think the X has different lighting modes.
« Reply #2 on: Wed, 07 May 2014, 18:52:13 »
Fun + q turns on ESC lock, and the LED under Esc.
Fn + space turns on cursor arrow lock, and the LEDs under the right side mods.
Offline BlueBär
« Reply #3 on: Wed, 07 May 2014, 18:55:26 »
Oooh right it's similar to the Pure in that aspect. I totally forgot about that.
Offline Jixr
« Reply #4 on: Wed, 07 May 2014, 20:08:02 »
well, I bought just the PCB, but it seems like Fn+W would = Up, but it dosent... I don't know why?
( dim switches are all off )
Offline BlueBär
« Reply #5 on: Thu, 08 May 2014, 02:16:38 »
Nevermind.
« Last Edit: Thu, 08 May 2014, 02:20:06 by BlueBär »
Offline Jixr
« Reply #6 on: Thu, 08 May 2014, 08:56:36 »
Okay, thanks guys, got it figured out.
