Author Topic: Realforce 87u or HHKB?  (Read 7181 times)
Offline Rafen
« on: Thu, 08 May 2014, 07:46:07 »
I just received my first topre board yesterday and I am in love! now I want to purchase another board for work and I can't decide on which one to get. I want the 87u in 55g like i have so there isn't much variation between what I have at work and home, but I use a Poker II at work so I'm thinking about getting the HHKB. Does the difference in switch weight make that much difference? Or will I be fine using a 45 and 55 board? I just don't want a bunch of variation between them so my fingers don't become weak from using lighter switches. Let me know what you think. Thanks for looking.
Offline ComradeSniper
  • HHKB Pro
Re: Realforce 87u or HHKB?
« Reply #1 on: Thu, 08 May 2014, 08:56:20 »
I have both and love them both. I don't think you should have any trouble going back and forth between the two.
Offline Defect
« Reply #2 on: Thu, 08 May 2014, 09:10:37 »
45g vs 55g
GG
Offline Rafen
« Reply #3 on: Thu, 08 May 2014, 09:16:04 »
I just went ahead and ordered the HHKB with a red ecs key! Now i got to sell some of my other boards  :p
Offline atlas3686
  • HHKB Elite
« Reply #4 on: Thu, 08 May 2014, 09:26:08 »
You not going to have any trouble, I have my HHKB at work and Realforce 55g at home and I have no problem what-so-ever. When I first started I would press the wrong backspace the first time I pressed it on the Realforce each day but you get used to that after a few days.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #5 on: Thu, 08 May 2014, 09:27:08 »
Good choice.
Offline esoomenona
  • Gnillort?
« Reply #6 on: Thu, 08 May 2014, 09:28:19 »
On my RF, I switched the Backspace and \| keys and Capslock for Ctrl with Keytweak, and Ctrl::Alt and Alt::Win with AHK to emulate the HHKB layout.
Offline Hypersphere
« Reply #7 on: Thu, 08 May 2014, 09:35:33 »
The HHKB is a great choice, especially for its combination of a 60% form factor and efficient/intuitive layout. In fact, I rotate among some rather diverse boards, including the HHKB Pro 2, IBM SSK, and IBM XT. I like the HHKB layout so much that I have remapped the IBM boards as closely as possible to the HHKB layout to make it easier to switch boards.
  • Cherry Peasant
  • keycult.com
« Reply #8 on: Thu, 08 May 2014, 09:59:14 »
Yep, I really enjoy the HHKB layout. Unfortunately though I need a split backspace because I use \ and ` quite a lot (as a programmer). I suppose I could manage with Backspace becoming \ and Fn-Esc being `, though.
Offline esoomenona
  • Gnillort?
« Reply #9 on: Thu, 08 May 2014, 10:05:52 »
But there is already a ` key, at the top left...
Offline eth0s
  • Peace & Love
« Reply #10 on: Thu, 08 May 2014, 11:23:39 »
Changing from 45g to 55g is not confusing, and your finger muscles will not atrophy while you're using the 45g keyboard.  However, switching back and forth between the RealForce and the HHKB is confusing to your muscle memory.  I do it almost everyday, and it takes me a minute or two to acclimate to the new layout.  Is this a horrible inconenience?  No.  It is mildly annoying though, I have to be honest.  But it hasn't stopped me from doing it.  And I switch between a 45g HHKB Type-S and a Variable weighted silent RealForce 87U.  Anyway, my advice is to get w/e you want, and don't worry about switching back and forth.
Offline aref
« Reply #11 on: Thu, 08 May 2014, 12:44:18 »
I used to have both 45- and 55-gram Topre 87U keyboards. I did have a problem when going from my 55g to my 45g. The 55g switch has exceptional feel for me; however, I found the 45g lacked feel. Odd as it sounds, when I want a change in key-switch feel after using the 55g Topre keyboard, I transition to a lighter Cherry key switch. Lately, I've been using an MX Red, 45g, KB, which has a completely different feel from Topre's 45g switch. I can also use MX Blue switches for a change in switch feel. However, Topre's 45g, at least for me, has an odd feel when coming from their 55g switch. The 45g feels kind of soft and mushy--it lacks feel, I'm repeating myself, mea culpa.
If you like the 55g switch, stay with it. The reasons I make a change in keyboards are twofold: my fingers tire after using the 55g switch for hours at a time; and at times I simply get somewhat bored with the same key-switch feel (I want to feel the mechanics of a key switch; and when I lose a switch's feel, I have to make a change, which helps [me] to maintain my momentum when writing).
My sense is that you should buy what suits you. And, you may want to note that the feel of Topre's 45g switch is much different from the 55g switch; to me it simply lacks the feel of Topre's 55g switch's properties.  My preference, not that this matters, is Topre's 55-gram inside an 87U keyboard. I've never used an HHKB; after buying 45g and 55g 87UBs, the Realforce 55g became my preferred keyboard and topre switch.
Whatever you choose, I wish you the best with your new keyboard, enjoy it.
« Last Edit: Thu, 08 May 2014, 12:59:42 by aref »
Offline AKIMbO
  • HHKBro
« Reply #12 on: Thu, 08 May 2014, 13:03:37 »
45g on hhkb feels way different compared to rf.
| KBD75 (box reds)
Offline aref
« Reply #13 on: Thu, 08 May 2014, 13:41:26 »
Akimbo:
I've read this from other HHKB users. I've never used an HHKB so I have no frame of reference.
How do Topre 45g switches on an HHKB feel compared with the same switch on a Realforce KB?
I know you've used both KBs; and getting some good comparative information would be helpful.
« Last Edit: Thu, 08 May 2014, 14:11:40 by aref »
Offline HannibalChew
  • Formerly PixelScript
    • gaffworks
« Reply #14 on: Thu, 08 May 2014, 17:02:52 »
HHKB all the way.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #15 on: Thu, 08 May 2014, 17:08:04 »
Realforce
Offline Macsmasher
« Reply #16 on: Thu, 08 May 2014, 17:33:08 »
I loved the backspace location on my HHKB so much I did the same. I used AHK.
  • Cherry Peasant
  • keycult.com
« Reply #17 on: Thu, 08 May 2014, 17:35:43 »
GET OUT OF HERE
Okay yeah you're right, I was stuck in the 60% mindset. Gonna do this with my TKL.
« Reply #18 on: Thu, 08 May 2014, 18:28:34 »
I like my HHKB, but I miss the arrow and function keys too much to use it for development at work.
Offline Rafen
« Reply #19 on: Thu, 08 May 2014, 21:08:20 »
I felt the same way when I first started using my Poker II but after a while I got use to it and don't mind the layout at all.
Offline Rafen
« Reply #20 on: Thu, 08 May 2014, 21:10:42 »
HHKB all the way.
I ended up ordering an HHKB in black (gray). Can't wait for it to get here.
Offline Rafen
« Reply #21 on: Thu, 08 May 2014, 21:11:34 »
In what way does it feel different?
Offline Polymer
« Reply #22 on: Thu, 08 May 2014, 23:01:12 »
I used to think this was really annoying but I basically forced myself to get used to it...now it doesn't take any time at all to switch back and forth..It is like learning to drive on both sides of the road..eventually you can do it without thinking about it..
What I think is weird is when I'm on my HHKB, the CTRL position is completely natural..but on my RF I swapped the CTRL to be in the same place as the HHKB (so where Capslock is normally) and when I switch back between the two I have to think about the CTRL on the RF but not at all on the HHKB even though they're the same position?  Not sure what it is...
Offline zoolzoo
« Reply #23 on: Fri, 09 May 2014, 13:47:15 »
Akimbo:
The HHKB switches are mounted onto the plastic case, while the RF switches are plate mounted.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline AKIMbO
  • HHKBro
« Reply #24 on: Fri, 09 May 2014, 16:26:46 »
Akimbo:
45g on a realforce feels mushy.  45g on an hhkb does not and is more tactile.
| KBD75 (box reds)
Offline Rafen
« Reply #25 on: Fri, 09 May 2014, 16:46:18 »
So the 45g on the HHKB would feel similar to the 55g on the Realforce ( not talking force but tactile feeling) ? I love how the 55g Realforce switches feel.
Offline atlas3686
  • HHKB Elite
« Reply #26 on: Fri, 09 May 2014, 17:14:17 »
The 55g is definitely still more tactile in my opinion.
Offline Rafen
« Reply #27 on: Sat, 10 May 2014, 06:23:03 »
Well I ordered the HHKB so I hope I enjoy the switch. I have been typing on reds for the last year and completely forgot about how amazing tactile feedback is.
Offline aref
« Reply #28 on: Sat, 10 May 2014, 18:39:00 »
Rafen: I know this was meant for Akimbo; but I thought I'd respond. To me, 45-gram Topre switches in a Realforce feel a bit soft, almost a bit mushy, nothing like an 87U with 55g Topre switches, which feel exceptional. However, as many have said, Topre's 45g switch feels different, firmer I would guess, in an HHKB. I'll look forward to your observations re the Happy Hacking KB. I hope that you find it a good purchase.
« Last Edit: Sun, 11 May 2014, 12:21:35 by aref »
« Reply #29 on: Sat, 10 May 2014, 19:10:43 »
If you've been enjoying the reds, 45g Topre will seem similar, just more thocky :)
