Author Topic: PokerX pcb issue?  (Read 1535 times)
Offline Jixr
PokerX pcb issue?
« on: Thu, 08 May 2014, 08:24:45 »
Hi, I just got a pokerX pcb in the mail, and I can't get the - [ ' keys to work.
At first I thought it was just a bad switch or solder joint, but I can't even get the key to activate by tripping it with a wire to complete the circuit. The pcb pad joints are not lifted or damaged it seems.
I don't know too much about PCB's and circuitry, but it seems like the affected keys are all connected via the pcb in a string like fashion.
I was wondering if anyone would have any ideas why the affected keys are not working?
« Last Edit: Thu, 08 May 2014, 08:49:31 by Jixr »
Re: PokerX pcb issue?
« Reply #1 on: Thu, 08 May 2014, 08:33:41 »
Could be a bad SMD diode (or a bad solder joint on that diode). It would require reflowing the solder or replacing the diode.
Offline Jixr
« Reply #2 on: Thu, 08 May 2014, 08:47:54 »
this is the SMD diode correct?
Do you think I could find a replacement at a radioshack or frys or other local electronics store?
I also I have a quickfire rapid that I could potentionally steal one from.
Do you think that one bad diode could affect multiple keys?
« Last Edit: Thu, 08 May 2014, 08:50:03 by Jixr »
« Reply #3 on: Thu, 08 May 2014, 08:49:30 »
1) this is the SMD diode correct?
2) Do you think I could find a replacement at a radioshack or frys or other electronics store?
1) Yes that's the SMD diode.
2) I'm not sure about Fry's but maybe at Radioshack? I usually see people ordering those from Mouser or Onlinecomponents. And harvesting them is obviously a possibility.
Offline Jixr
« Reply #4 on: Thu, 08 May 2014, 17:51:29 »
Is there any way to determine which one may be bad or how to test them?
from what I understand, a diode directs the flow of power, and if they are wired in a chain, if one switch isn't getting power ( which its not ) then i would kill the switches behind it?
I bought the PCB off a memeber on here, and I would like to get it working as I was told it was when I bought it.
Offline Jixr
« Reply #5 on: Thu, 08 May 2014, 20:40:36 »
well i took off one diode on a switch i know to be good, and I could just hard wire the diode and the key would trip, tried that on the bad ones and still no dice.
I guess its just dead.
