Author Topic: PBT keycaps with LED covered with LED cover  (Read 4395 times)
Offline zennasyndroxx
  • It's good to be back!
« on: Thu, 08 May 2014, 22:17:32 »
Hi guys,
(first of all, I'm sorry if I've posted in the wrong section)
To those who have LED backlit keyboards and currently using LED cover, when you guys are using non shinethrough PBT keycaps, will the glow around the keycap be any bright?
Pictures will be appreciated :3
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
Re: PBT keycaps with LED covered with LED cover
« Reply #1 on: Fri, 09 May 2014, 00:22:18 »
What is an LED cover? Serious question.
Offline OnTheBrink
    • Wired In Store
« Reply #3 on: Fri, 09 May 2014, 14:50:42 »
This, http://www.banggood.com/DayDream-LED-Cover-For-108-Mechanical-Keyboard-White-Backlit-p-925837.html
Thanks. I just bought a set. I'll let you know in 5-20 days as I have black PBTs and white backlight.
Offline JinDesu
« Reply #4 on: Fri, 09 May 2014, 15:12:44 »
They shine through pretty well if the PBT cap is a lighter color.
See:
The top row on either side of the backspace is white PBT caps. The glow around them is no different than the glow around the other caps.
Someday somebody will best me, but it won't be today, and it won't be you.
Proud owner of a Filco Majestouch Cherry MX Blue Tenkeyless, KBT Race S, & Realforce 101
« Reply #5 on: Fri, 09 May 2014, 21:35:46 »
See:
thanks! :D
even the darker covers give out a pretty good glow. planning on either ducky abs with shinethrough legends or just pbts for my coming keyboard. phew i can buy the cover with no worries now :D
Offline Aidenknives
« Reply #6 on: Wed, 09 July 2014, 22:01:22 »
See:
Where did you get those PBT keycaps for the vortex race?
Offline JinDesu
« Reply #7 on: Wed, 09 July 2014, 22:07:42 »
See:
The bottom keycaps, the ones with text, are ABS. I was referring to the top row (was being lazy, grabbed the first picture I got) where I'm using custom R4 pad printed thin PBT white caps in lieu of my number row. Hence the comment, to the left and right of the backspace. It's a little deceiving, I apologize for that.
