Author Topic: cheapest numeric pad with reds  (Read 1896 times)
Offline Jaky
« on: Fri, 09 May 2014, 06:08:13 »
Amazon only sells filco blue tkp >( do any of you know a store that ships internationally doesn't matter the brand. THANKS@! XDXD
poker 2 red | shine 3 (yellow) brown | corsair K70 blue
 ^_^ zinc keys <3
Offline Jaky
Re: cheapest numeric pad with reds
« Reply #1 on: Fri, 09 May 2014, 06:11:16 »
Sorry I didn't clarify the subject right :P
 ^_^ zinc keys <3
Offline kohi
Offline eth0s
  • Peace & Love
« Reply #3 on: Fri, 09 May 2014, 18:52:22 »
not sure if it'll meet your budget but I found one on ebay
http://www.ebay.com/itm/Leopold-210TP-Mechanical-number-Pad-Cherry-MX-Red-Gravy-color-/291087814426?pt=PCA_Mice_Trackballs&hash=item43c62f8f1a
That's actually a really nice numpad, with the grey keys.  And Qtan is an awesome dude.
« Reply #4 on: Fri, 09 May 2014, 20:08:45 »
If you buy from his store, you get better pricing:
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-br/leopold-210tp-mechanical-keypa/lid=35137624
I believe Australia has no import fees for items under $1000
Offline Jaky
« Reply #5 on: Sat, 10 May 2014, 06:23:22 »
I was looking at this one earlier, I do like the grey cap (or "gravy colour" LOL) and leopold is an amazing brand, but maybe a bit expensive true. I don't know, anyway thank you guys for the reply's, I appreciate the help :3
 ^_^ zinc keys <3
Offline Rafen
« Reply #6 on: Sat, 10 May 2014, 06:25:37 »
You could always buy a cheap number pad and then swap the switches. Won't be hard to do and fairly cheap since you only need a small number of switches.
Offline Jaky
« Reply #7 on: Sun, 11 May 2014, 06:40:54 »
True, though I don't want to wait on two separate orders and then have to diy when it's only 30-50.
 ^_^ zinc keys <3
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Sun, 11 May 2014, 14:03:02 »
Be careful if you decide to go for a Leopold keypad. There is at least 2 revisions of it and one of them firmware does not send the numpad number scancodes which may be highly annoying depending on what you want it for. You might also consider the Keycool model, it is very similar.
Offline Jaky
« Reply #9 on: Mon, 12 May 2014, 08:38:27 »
Thanks for the insight, I'll have a look at the keycool too. btw how is the build quality, would it survive a half meter fall  :p
 ^_^ zinc keys <3
