Author Topic: un-LED'ed 'M... now with LED's!  (Read 3597 times)
Offline phosphorglow
  • Model M Mechanic.
    • Phosphor Glow
« on: Fri, 09 May 2014, 15:57:27 »
Terminal board I got bored with. Sure, it was gorgeous and clean and felt wonderful. But it was boring. So I swapped over some keycaps and left the super awesome ones, added in the number pad "+" key, and decided to utilize the controllers status LED capability by lighting the Caps/Scroll/Num keys from underneath.
I think it looks absolutely freaking cool. The bee's knees, if you will. :D
It's rather subtle in normal lighting, and incredibly epic looking in low light.
Re: un-LED'ed 'M... now with LED's!
« Reply #1 on: Fri, 09 May 2014, 15:59:47 »
These are some awesome pictures. All of the artsy angles are covered!
  • Model M Mechanic.
    • Phosphor Glow
« Reply #2 on: Fri, 09 May 2014, 16:24:17 »
Thanks!  :D
« Reply #3 on: Sat, 10 May 2014, 01:20:41 »
An interesting mod!  Most people probably would have just replaced the case top and added the LED board.
