Author Topic: Removing 00 from Numeric keypads  (Read 2958 times)
Offline James35
« on: Sat, 10 May 2014, 16:55:28 »
I searched but couldn't find an answer to this. I'm researching mechanical numpads and most have 0 and 00 (double zero). Can buy a 2.0 key cap to span both the 0 and 00?  If I do this I'm assuming I'd need to desolder the 00 switch or maybe use AutoHotKey?
I currently have my eye on something like the Keycool 22 (because I would like backlit).
« Last Edit: Sat, 10 May 2014, 17:07:30 by James35 »
Offline Pacifist
  • on hiatus
Re: Removing 00 from Numeric keypads
« Reply #1 on: Sat, 10 May 2014, 17:21:51 »
most keypads I see have a 2x 0...but you could get one of those rose system 2x keys and then disable the 00 key
Offline RabRhee
« Reply #2 on: Sat, 10 May 2014, 17:27:11 »
POS keycaps have double stems like that, you would just have to disable the 00 from working. Here is a shot of a POS two stem 00 key on my Goldtouch keypad. It should work, and lots of crap bag owners have keys that could work, nothing backlit I think though.
64307-0
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline James35
« Reply #3 on: Sat, 10 May 2014, 17:54:07 »
And by disable, do you mean mechanically disable it or can it be done via software or firmware?
Offline Pacifist
  • on hiatus
« Reply #4 on: Sat, 10 May 2014, 17:56:37 »
either remove the pins from the actual pad, or use scripts to disable it
