Author Topic: Deathadder 4g and mamba mashup?  (Read 4410 times)
Offline Naweo
« on: Sat, 10 May 2014, 18:32:46 »
Does anyone know if it is possible to do a deathadder 2013/4g sensor and put it into a razer mamba shell casing, including functioning 2 macro button on mouse leftclick?
If yes, or if you know a possible guide, or if someone is willing to do it for a prestigious cost, let me know!
Offline Cheesebaron
    • blog
Re: Deathadder 4g and mamba mashup?
« Reply #1 on: Sat, 10 May 2014, 18:59:02 »
Everything is possible if you have the will in your heart.
MINILA       Poker II       Model M
MX Blue      MX Blue       SSK '88
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #2 on: Sat, 10 May 2014, 19:15:59 »
Or money.
Or good looks.
Or luck.
Or skill.
Or money.
Or starship enterprise.
Offline Naweo
« Reply #3 on: Sat, 10 May 2014, 19:29:59 »
I got money :OOOO
Offline Novus
  • Mondai nothing~
« Reply #4 on: Sat, 10 May 2014, 19:38:13 »
Wait Mamba is the wireless one right? In that case, I don't think that's possible.
Offline munch
« Reply #5 on: Sat, 10 May 2014, 19:42:19 »
possible but would probably require an entire R&D department... :P so, many many thousands of dollars.
Offline Naweo
« Reply #6 on: Sat, 10 May 2014, 19:48:39 »
Thousands of dollars? Like 3000?
Offline munch
« Reply #7 on: Sat, 10 May 2014, 19:59:10 »
well, I'd assume that you'd need to make an entire new shell to get the sensor working well, and then figure out just how to get the wireless transmitter working with the sensor and what kind of battery you'd need for both the transmitter and the sensor as well... then the buttons and whatnot too. it's not a particularly simple process I'd imagine.
not just a transplant :(
Offline Bucake
« Reply #8 on: Sun, 11 May 2014, 03:37:00 »
drill a hole for the cable, is that not an option?
but i guess munch is right. making the deathadder wireless and making it support those macro buttons is not exactly a simple DIY project anymore :x
« Last Edit: Sun, 11 May 2014, 03:41:07 by Bucake »
Offline Naweo
« Reply #9 on: Sun, 11 May 2014, 14:37:46 »
But isnt mamba a wired AND wireless at the same time?
Offline munch
« Reply #10 on: Sun, 11 May 2014, 18:23:28 »
it is, but you'd still need a way to get the two macro buttons to work together with the sensor and such. I'd assume that'd mean a custom firmware.
I'd imagine adding two buttons to the Deathadder would be an easier thing to pull off, but still require a custom firmware? and I'd guess only Razer could do that. :(
