Author Topic: Wobbly Keyboard  (Read 4339 times)
Offline Classic
Wobbly Keyboard
« on: Sat, 10 May 2014, 21:54:30 »
Does anyone have any suggestions on how to fix a wobbly keyboard? Thank you very much for your time.
Re: Wobbly Keyboard
« Reply #1 on: Sat, 10 May 2014, 22:14:13 »
Get some of the waffle-like rubber shelf liner from Wal-Mart and cut a piece to fit.
- D Trump 2026-09-28
Re: Wobbly Keyboard
« Reply #2 on: Sun, 11 May 2014, 01:39:39 »
my desk isn't flat, so I folded a business card in half and slid it under my lightsaver until it didn't wobble. I imagine a large mouse mat would work too.
Re: Wobbly Keyboard
« Reply #3 on: Sun, 11 May 2014, 02:40:09 »
If it wobbles diagonally, you should be able to grasp diagonally opposite corners of the keyboard and give it a little twist.
I did that with one of mine (can't remember which one now) - wobble gone!
Re: Wobbly Keyboard
« Reply #4 on: Sun, 11 May 2014, 03:20:31 »
I just tried this on my lightsaver with aluminium case, It didn't work. maybe I'm not twisting hard enough?
Re: Wobbly Keyboard
« Reply #5 on: Sun, 11 May 2014, 03:32:08 »
Probably the aluminium case :))
Mine had a plastic case (as all my keyboards do), and a plate.  Didn't take much force to twist it very slightly.
Offline aref
Re: Wobbly Keyboard
« Reply #6 on: Sun, 11 May 2014, 15:25:02 »
If your desk is uneven, get some thin self-stick felt pads, hardware store, and level your keyboard to
fit your desktop. Or you can level your desktop in any way you choose; then add a piece of flat wood
sheeting, make sure the sheeting is not warped, and affix it to your level desktop.
Offline SSIPAK
  • ★ Bootlegcaps ★
Re: Wobbly Keyboard
« Reply #7 on: Sun, 11 May 2014, 23:11:06 »
post it or business card
Offline Classic
Re: Wobbly Keyboard
« Reply #8 on: Mon, 12 May 2014, 18:27:22 »
Thank you very much for the tip. I tried that method today and it worked perfectly!
Offline Premonition
  • HHKB Elite
Re: Wobbly Keyboard
« Reply #9 on: Mon, 12 May 2014, 20:06:10 »
My god, you are a wizard! That worked completely!
Offline zoolzoo
Re: Wobbly Keyboard
« Reply #10 on: Mon, 12 May 2014, 20:09:02 »
I think he trolled you!
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Re: Wobbly Keyboard
« Reply #11 on: Mon, 12 May 2014, 21:20:34 »
I think so too.
Although the same principal should apply - you just have to twist a LOT harder :))
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Wobbly Keyboard
« Reply #12 on: Tue, 13 May 2014, 01:16:45 »
My Das we twisted pretty bad after using it with a fairly thick mouse pad under one side due to my keyboard tray not being wide enough for those and my Orbweaver.  So when I moved my keyboard to the top of my desk I just put a stack of paper under one foot and gradually removed a sheet or two.  After a while it was straight again.
