Author Topic: CLEARANCE RANGE - Must go!  (Read 11610 times)
Offline pexon
  • * Moderator
  • El Jefe of Sleeving
    • Pexon PCs
« on: Sun, 11 May 2014, 07:52:39 »
Hi dudes and dudettes, I've got the clearance cables sorted, they need to go! Extra 10% off auto applied at the checkout!
Check them out here:- http://pexonpcs.co.uk/Clearance-USB-Cables-_p_45.html
Offline amos5606
Re: CLEARANCE RANGE - Must go!
« Reply #1 on: Sun, 11 May 2014, 09:19:24 »
I. Mini USB 3ft Matte Purple - £1.00
ohhhh
It's the price error right ?
What will fill your hearts with delight ,,
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #2 on: Sun, 11 May 2014, 09:21:15 »
OOOOPS! It was meant to be 10.00  ???
« Reply #3 on: Sun, 11 May 2014, 10:29:23 »
cool
Offline pexon
  • * Moderator
    • Pexon PCs
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #5 on: Fri, 16 May 2014, 17:29:41 »
Still a few left. Will be adding more MDPC-X ones tomorrow  :thumb:
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #6 on: Fri, 16 May 2014, 18:24:19 »
Bought a couple. Let's hope they work work for what I want with them. (making a Leopold keypad with detachable cable.)
|||My other keyboards :
x
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #7 on: Sat, 17 May 2014, 06:30:45 »
Will get yours packed up this weekend and posted on monday boss  :thumb:
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #8 on: Tue, 03 June 2014, 07:33:37 »
Cables arrived today and I can tell you do use some quality cables with extra shielding.  :thumb:
The initial plan however failed as the Leopold has a smaller connector inside.
And my own modding kind of ruined the usb-connector... (sorry Pexon) :'(
Do you think you can get a smaller connector and make a new one?
x
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #9 on: Tue, 03 June 2014, 09:50:29 »
Glad they got there safe man! Don't worry about the modding, all power to you!  :thumb:
I can have a look for a smaller connector for you, but no guarantees I can find the exact Leopold one.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #10 on: Tue, 03 June 2014, 10:04:42 »
Thanks! Let me know if you need any info like sizes and such.
x
Offline IonutZ
  • Stay awhile and listen
    • SC
« Reply #11 on: Mon, 16 June 2014, 16:07:15 »
Cool products! Looking for some PSU sleeving, will contact!
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #12 on: Mon, 16 June 2014, 16:32:28 »
Thanks a lot man! I love PSU sleeving  8)
