Author Topic: Looking for similar sound/feel. Please help.  (Read 4583 times)
Offline pcross84
« on: Fri, 24 April 2009, 00:37:56 »
Hi there - I'm looking for a keyboard with a certain feel and sound. Right now, I'm using a Dell AT101W and it's kind of close, but what I'm looking for is more of a plastic "clack", kind of like the terminal keyboards they used to have at the library. (WYSE)
The BEST keyboard I ever used was when I was 17 and worked at the telephone company. It was a Nortel TOPS IWS Keyboard (Nortel Part #NTNX51HH). I cannot buy one because I don't have a carrier license. If anyone knows what kind of keyswitches this one had, and if there's a consumer keyboard with those same switches, please let me know!
Buckling spring keyboards are too metallic sounding, and require too much force.
This AT101W has almost the right sound, but the force is still too high.
I may be looking for something with both a spring and a membrane. Not sure.
Thanks for your help!
Offline lowpoly
« Reply #2 on: Fri, 24 April 2009, 05:39:21 »
Did you go through the keyboard audio clips yet?
Offline pcross84
« Reply #3 on: Fri, 24 April 2009, 10:59:53 »
Yes, I sure did. It gives a great clue as to how a keyboard would sound. I'm just wondering what kind of mechanism I'm looking for. This particular keyboard made a plastic "clack", but did not require much force. It was a really satisfying sound and had great spring-back.
I'm still learning the terminology like "bottoming out".
Thanks for helping the noob.
Offline Manyak
« Reply #4 on: Fri, 24 April 2009, 11:09:47 »
http://www.cdrinternational.net/products/NORTEL%20NETWORKS/pg415.php#thumb
About the closest I could get to actually buying it.
Have you tried calling up Nortel or the phone company and asking them? Maybe they'll be able to tell you.
Currently Owned:
Filco FKBN104MC/EB - Model M 1390131 \'86 - Model M 1391401 NIB - Unicomp Endurapro NIB - iRocks KR-6230 - Compaq MX-11800 - Cherry G80-8113HRBUS-2 - Cherry ML-4100 - Cherry MY-8000-something - Dell AT101W (Black) - ABS M1 - Siig Minitouch - Chicony KB-5181 w/ SMK Montereys - Chicony KB-5181 w/ SMK Montereys NIB - Cherry G80-3494LYCUS-2 - Deck Legend
Offline pcross84
« Reply #5 on: Fri, 24 April 2009, 11:25:17 »
Nortel requires licensing for this product, and since I don't run a carrier-class company, I can't get licensed. Plus, these aren't in production.
I could try calling the phone company, but, when I worked there, systems and metrics information were "proprietary", so, I doubt they'd even discuss it with me.
Offline lowpoly
« Reply #6 on: Fri, 24 April 2009, 11:28:46 »
Drop by your old company and while you say hello pull a keycap. :smile:
Offline pcross84
« Reply #7 on: Fri, 24 April 2009, 11:30:00 »
LOL sure, I'll just waltz right past the guards and pray that the doors unlock without a keycard :)
Blue sliders maybe? capacitive? hmm...
Offline Manyak
« Reply #8 on: Fri, 24 April 2009, 12:40:18 »
Well I guess your best bet would be to try out a bunch of cheap keyboards with all types of switches until you find the ones you want.
Currently Owned:
Offline cchan
« Reply #9 on: Fri, 24 April 2009, 19:40:06 »
Old wyse keyboards generally have cherry black switches. Take a look at the cherry mx11900 (also called g80-11900) on ebay. It's a black switch keyboard with an inbuilt touchpad. If you're lucky, you can get one for about thirty bucks...
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline pcross84
Found one! -- Screw the nortel keyboard
« Reply #10 on: Fri, 01 May 2009, 21:03:09 »
Okay, I just got my Apple Extended II in the mail, and the touch and feel, and sound (click-clock) is absolutely the best feeling thing -- ever. It's light, but the bump is affirming.
Also, I dyed it with the instructions in the mods section. Pics to follow.
Thanks for everyone's help!
Offline pcross84
« Reply #11 on: Wed, 06 May 2009, 16:37:02 »
After searching high and low, I found a Japanese site with information about the keyswitches used in the Nortel IWS keyboard. They're called black axis and they're by Cherry. A filco majestouch has those in it, right?
Offline IBI
« Reply #12 on: Wed, 06 May 2009, 16:39:59 »
Quote from: pcross84;89593
They're probably the Cherry MX linear switches then. Lots of keyboards use them, all of Cherry's G80 range is availible with them for example.
I'm surprised it's those ones though, since they've got pretty strong springs.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline bhtooefr
    • bhtooefr.org
« Reply #13 on: Wed, 06 May 2009, 16:42:54 »
You can get a Majestouch with those, yes.
The only one with blacks that EliteKeyboards (the US distributor for Diatec) carries is a tenkeyless, though: http://elitekeyboards.com/products.php?sub=filco_keyboards,majestouch_87key&pid=fkbn87mleb
Alternately, if you'd rather have a numpad, the Deck Legend also has blacks. Or, if you're dirt cheap, there's a few variants of the Cherry G80-3000. (I forget exact model numbers.)
Offline Manyak
« Reply #14 on: Wed, 06 May 2009, 16:52:30 »
Quote from: bhtooefr;89595
Don't forget the Steelseries 7G!
Currently Owned:
Offline IBI
« Reply #15 on: Wed, 06 May 2009, 18:07:00 »
Quote from: Manyak;89600
And the Steelseries 6G! And the Raptor-Gaming K1!
Offline pcross84
« Reply #16 on: Thu, 07 May 2009, 07:28:15 »
ftw. wish I had it.
Offline pcross84
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #18 on: Thu, 07 May 2009, 07:37:09 »
Looks like that particular one has Cherry blacks. Lots of special and custom-labeled keys there, too.
