Author Topic: televideo 950  (Read 2249 times)
televideo 950
« on: Tue, 13 May 2014, 03:26:48 »
http://www.ebay.com/itm/331201899989
I have one of these. It features linear futabas and is quite well made.
I would say that it is one of the best keyboards I have in terms of build quality.
Some caveats:
1. The switches are quite heavy: probably a little more than MX blacks.
2. if it's well used like mine then it'll be very scratch and horrible to type on.
To alleviate #2 you can take it apart, lube the switches and then direct wire. You'll be left with a great-feeling linear board that's built well and has a decent layout.
I would recommend this to someone looking for a project and a deal, which is why I posted about it here.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Re: televideo 950
« Reply #1 on: Tue, 13 May 2014, 12:00:24 »
Is that keyboard compatible with a computer running Windows?
Offline Tarzan
  • formerly known as Greystoke
Re: televideo 950
« Reply #2 on: Tue, 13 May 2014, 12:14:56 »
Not in it's stock form.  I built one using the stock case/switches and a hardwired layout to a Teensy that was pretty interesting.
Offline False_Dmitry_II
Re: televideo 950
« Reply #3 on: Wed, 14 May 2014, 18:19:22 »
Have you done anything with your space invader televideo yet?
Offline 1391406
Re: televideo 950
« Reply #4 on: Sat, 17 May 2014, 13:18:59 »
So these will, in fact, work with a Teensy as an external converter?
Offline Tarzan
Re: televideo 950
« Reply #5 on: Sat, 17 May 2014, 13:20:12 »
Not as far as I know.
Re: televideo 950
« Reply #6 on: Sat, 17 May 2014, 16:02:41 »
If you then figure out the protocol and add it to something like soarers. That would totally work then.
