Author Topic: KPT-102 Review  (Read 30848 times)
Offline Altis
KPT-102 Review
« on: Tue, 13 May 2014, 17:21:51 »
Hello fellow Geekhackers,
I thought I would write a little bit about the KPT-102 as there doesn't seem to be much information on it anywhere. This is my first review, so be kind.
I got this keyboard from a good friend of mine. It's the first mechanical keyboard I have ever used, back in the early 90s. I remember thinking it was really unique at the time, but never thought much of it until I got into keyboards. First thing I did of course was a full restore: took it all apart, cleaned everything thoroughly, cleaned and greased the switches.
The keyboard uses KPT alps (blue rectangular), which are clicky, very tactile, and fairly heavy. The switches are mounted on a plastic plate, and the body does seem to have a noticeable amount of flex and makes noise under pressure. This explains why it is a pretty lightweight keyboard. The keycaps feel pretty smooth, and are not pad-printed but rather double-shot. There are two uniquely-placed "\ |" keys in between the Ctrl and Alt keys on either side. The locking indicators are red, yellow, and green (in that order).
The keys feel quite and sound quite substantial. I would say they are heavier and more tactile than MX Blues, although I haven't tried Greens. I would describe them as 'crunchy', and some of the keys -- the less used groups (F-keys, upper right clusters) -- are particularly crunchy/snappy. The keys make quite a bit of noise overall, and have a hollow metallic 'ping' that can be heard upon upstroke.
The angle is quite steep when the feet are extended, and oddly enough, the two rubber pads located under the near-side of the keyboard are lifted off the surface when the feet are out, making it very easy to slide around. When the feet are retracted, the keyboard stays in place easily and the angle is normal.
The keyboard uses a 5-DIN connector, which I have rewired to a PS/2 connector. Strangely, there is a switch located near the connector on the electronic board itself that seems to prevent the keyboard from working. I had it wired up and could get the locking keys to work (light up the indicators), but no response from any other keys. I took it apart and moved the switch to the other position, and now it works normally. Not sure if it does something to the connections, perhaps changes the pin-out.
If you have any questions, feel free to ask and I will do my best to help. Thanks!
Altis
« Last Edit: Tue, 13 May 2014, 20:47:18 by Altis »
Re: KPT-102 Review
« Reply #1 on: Tue, 13 May 2014, 18:48:48 »
KPT switch info here.
Offline Altis
Re: KPT-102 Review
« Reply #2 on: Tue, 13 May 2014, 20:44:33 »
Thanks, Rowdy. Wasn't sure about posting a reference to Deskthority Wiki.
Re: KPT-102 Review
« Reply #3 on: Tue, 13 May 2014, 21:32:07 »
It happens :p
We are trying to rebuild the GH wiki.
Offline Pacifist
  • on hiatus
Re: KPT-102 Review
« Reply #4 on: Tue, 13 May 2014, 21:47:08 »
It happens :p
cept its really not happening :'(
Offline Altis
Re: KPT-102 Review
« Reply #5 on: Thu, 15 May 2014, 11:43:59 »
I should also note that it's substantially louder than my Model M. It's currently the loudest keyboard I have, overall.
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: KPT-102 Review
« Reply #6 on: Thu, 15 May 2014, 11:46:20 »
Are the switches comparable or exactly the same as Blue Alps? I'm assuming yes? Nice board!
Re: KPT-102 Review
« Reply #7 on: Thu, 15 May 2014, 11:49:42 »
IIRC from my testing, they didn't feel like complicated Blue Alps. A bit too stiff and crunchy as Altis pointed out in his review.
Nice review Altis. I wonder if that switch changes the keyboard from AT to XT and that's why it wasn't working.
Offline AKIMbO
  • HHKBro
Re: KPT-102 Review
« Reply #8 on: Thu, 15 May 2014, 13:09:41 »
I agree with CPT, they feel nothing like comp blues.  KPT switches are meh tbh...however the caps are a direct swap for true alps boards and almost always doubleshot. There are usually several cyrillic kpt boards on  ebay at any given moment.
| KBD75 (box reds)
Offline Altis
Re: KPT-102 Review
« Reply #9 on: Thu, 15 May 2014, 16:18:32 »
I haven't used Blue Alps, only black (in an AT101), so I'm not sure how they would compare. They are certainly loud, tactile, and quite heavy. The word that comes to mind when I use them is 'crunchy', for sure. I think the nature of the casing and plate add to this.
That could very well be. I didn't play with it too much once it started working.
« Last Edit: Tue, 18 August 2026, 18:06:59 by Altis »
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: KPT-102 Review
« Reply #10 on: Tue, 03 June 2014, 19:14:22 »
Hello Altis
Could I trouble you please for a photo of the rear label confirming the FCC ID, for reference purposes? It should say "IYNKPT-102", the same as the better-known, but really tacky-looking version:
http://kbtalking.cool3c.com/article/13939
Thanks
Bore Awards
Offline Altis
Re: KPT-102 Review
« Reply #11 on: Sat, 07 June 2014, 00:29:04 »
Hello Altis
Thanks
I will post a photo tomorrow, but it does say "IYNKPT-102" next to FCC ID on the rear label.
  • RIP
    • Boring twaddle
Re: KPT-102 Review
« Reply #12 on: Sat, 07 June 2014, 06:57:30 »
Thanks.
I've just realised: those are Tai-Hao keycaps.
Interestingly, it's also got one if not two of the keycaps I'm looking for: 2u backspace and front row backslash, as unyellowed Tai-Hao. (Not sure how well the backslash would work between shift and Z on an ISO board.) I also need a Tai-Hao caps lock, but it's for an AT102W which has a stupid non-standard stepped caps lock that's something like 1 mm out from a normal keycap. The caps lock keycap I do have doesn't fit.
Bore Awards
Offline Altis
Re: KPT-102 Review
« Reply #13 on: Sun, 08 June 2014, 13:38:08 »
Thanks.
Did you still want a photo of the label, or was it just the FCC ID you were interested in?
  • RIP
    • Boring twaddle
Re: KPT-102 Review
« Reply #14 on: Sun, 08 June 2014, 15:37:15 »
I wanted to confirm the FCC ID, but having a photo is always good as it prevents anyone from doubting.
Bore Awards
Offline anasana
Re: KPT-102 Review
« Reply #15 on: Sat, 01 March 2025, 09:13:08 »
I found today the same keyboard, KPT-102, Made in Taiwan, Cyrillic locals. Is it need to dump the P8049 controller mask ROM?
Or it firmware is already exist somewhere like MAME, etc.?
FCC ID: HEU 292
Serial No: 1991020032
« Last Edit: Sat, 01 March 2025, 09:22:03 by anasana »
