Author Topic: iPhone USB connector  (Read 1810 times)
Offline swill
  • builder & enabler
    • swillkb.com
« on: Tue, 13 May 2014, 17:27:30 »
Does anyone know where I can buy the 30 pin connectors so I can make my own iPhone 4 USB cable?
I have looked all over the place and I am having no luck.
Offline OverKill
Re: iPhone USB connector
« Reply #1 on: Wed, 14 May 2014, 08:39:24 »
since like alll apple products it is patented im guesing apple. buy a cable and cut off usb side and replace with usb female or whatrvert
Offline jacobolus
« Reply #2 on: Thu, 15 May 2014, 00:02:20 »
http://www.monoprice.com/Search/Index?keyword=30-pin
Not sure if you can find just the connectors anywhere. I’m sure you can find other cable options on ebay, etc.
