Author Topic: Keyboards with the PN key  (Read 16043 times)
Offline roaming pear
  • THE Roaming Pear
« on: Wed, 14 May 2014, 00:00:20 »
Is the Poker 2 the only keyboard that has the PN key?
This is an amazing key......
But I haven't seen any other keyboards use such a programmable button..
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Offline spiceBar
    • ChessTiger.com
Re: Keyboards with the PN key
« Reply #1 on: Wed, 14 May 2014, 00:17:03 »
Poker Pure PRO and Ducky Mini also have it. I'm pretty sure the Pure PRO has the same controller as the Poker 2, as I own both. I'm not sure about the Ducky Mini, but it's probably the same.
Please note that the Poker PURE is not programmable. Only the Pure PRO is.
Here is a nice way to use the programming feature of the Poker 2:
  http://geekhack.org/index.php?topic=57723.msg1313182#msg1313182
Offline Oobly
« Reply #2 on: Wed, 14 May 2014, 01:20:48 »
I think you meant KBT Pure Pro. KBT is the manufacturer, Poker is a model like Pure and Pure Pro. The Poker 2 and Pure Pro programmable feature is really cool, makes them REALLY flexible in terms of character layout. The Poker 2 has more aftermarket keycap options, though, since it has a standard ANSI layout.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline exitfire401
  • The Force is Re/\l
« Reply #3 on: Wed, 14 May 2014, 01:21:18 »
Race 2 has one.
Offline spiceBar
    • ChessTiger.com
« Reply #4 on: Wed, 14 May 2014, 01:35:43 »
Yes, you are correct, it's KBT Pure Pro, not Poker.
  • THE Roaming Pear
« Reply #5 on: Wed, 14 May 2014, 13:00:32 »
I had already used deskthority's wiki on the poker 2 to program it, but I think the page you link to might have some info that wasn't there or wasn't clearly written. Thanks  ^_^
I love the PN key...
What does PN stand for anyway?
I assume FN is function... but how about PN? Punction?
Offline YummyTreeSap
« Reply #6 on: Wed, 14 May 2014, 13:33:49 »
Progranning.
« Reply #7 on: Wed, 14 May 2014, 14:34:19 »
My Ducky mini has it :)
« Reply #8 on: Wed, 14 May 2014, 15:05:08 »
Like so many things with keyboards, the origin is in the distant past of computing, and is often forgotten in the modern use.
Keyboards have had Function keys for the longest time.  In modern use they are fairly generic but they were mostly application specific in the old days.  PC keyboards had F1 through F12, but other systems had more (F24, etc.).  "Fn" just refers to the scheme of calling them F with a number.  'N' = number
In addition to the dedicated, application-specific Fn keys, many systems had programmable function keys, PF1, PF2, PF3, etc.  Those keys could be programmed to extended characters or combination keystrokes and they were used extensively in point of sale systems, banking systems, booking systems, and the like.  They usually had the same numbering scheme.
So, "Fn" is an obvious shorthand for "Function", and "Pn" follows for "Programmable Function".
These modern boards seem to use "Pn" for programming even though they don't have any PFn keys.
  • THE Roaming Pear
« Reply #9 on: Wed, 14 May 2014, 15:32:15 »
I see.  Thank you for that info. ^_^
Offline Grendel
« Reply #10 on: Wed, 14 May 2014, 16:21:24 »
The new Deck boards have one. Although no PN-lock IIRC.
- I'm game !
