Author Topic: Where to buy Leopold (or compatible) TKL Keyboard Cover?  (Read 1413 times)
Offline hsu
« on: Wed, 14 May 2014, 12:13:31 »
Hi guys,
how do you recommend that I fix a Leopold keyboard that the cover was damaged (by bad painting over bad painting)?
Creative solutions are welcome.
Is there a "coverless" mod maybe?
I can't find the part anyhwhere.
Thanks
Re: Where to buy Leopold (or compatible) TKL Keyboard Cover?
« Reply #1 on: Wed, 14 May 2014, 12:15:25 »
Sand all the paint off and try it again? Or try seeing if a QFR top will fit your Leopold.
A coverless mod? Not much of a mod, you can just rock the keyboard without the top without a problem. I mean the Epsilon board I have has an exposed PCB. It might look funny but it will work fine.
