Author Topic: Mass drop finds  (Read 4056 times)
Offline intelli78
Re: Mass drop finds
« Reply #1 on: Wed, 14 May 2014, 14:56:41 »
Are those really POM keycaps on the Noppoo? I am skeptical. Never seen backlit POM before.
Offline Pacifist
  • on hiatus
Re: Mass drop finds
« Reply #2 on: Wed, 14 May 2014, 15:06:10 »
**** U NOPPO NOW I NEED TO GET ANOTHER 75% BOARD ****KKKKKKKKKKKKKK
Offline Pacifist
  • on hiatus
Re: Mass drop finds
« Reply #3 on: Wed, 14 May 2014, 15:12:15 »
but looks like they are fixing all the debouncing ****. KC quality goes down, noppo quality goes up, my wallet=0
edit: but that spacebar doe :'(
Re: Mass drop finds
« Reply #4 on: Wed, 14 May 2014, 15:23:17 »
I don't think they'd say it's POM if it weren't. The black surface will be some kind of paint, not POM though. The transparent part will be POM.
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Mass drop finds
« Reply #5 on: Wed, 14 May 2014, 15:24:49 »
Very similar to what Deck was doing. Basically Painted POM that has the paint lazered off for the legends.
Offline Lain1911
  • God of the Wired
Re: Mass drop finds
« Reply #6 on: Wed, 14 May 2014, 15:49:23 »
No one said anything about the doubleshots. Are they worth it?
Offline J0hn
Re: Mass drop finds
« Reply #7 on: Wed, 14 May 2014, 15:49:48 »
I thought deck was doing reverse dyesub on their old keyboards?
Offline jwaz
  • * based mod
Re: Mass drop finds
« Reply #8 on: Wed, 14 May 2014, 15:54:56 »
I guess you're right:
Will the letters on the keycaps wear off eventually?
NEVER! Characters can't chip off the key caps or wear down because we use a sublimated negative printing process which drives the ink into the plastic keycaps at 525°F. This means permanent printing from the inside out, not just on the top, and gives the letters a permanent place inside the plastic.
I can't seem to find any pictures of worn Deck caps, maybe I was thinking Black Widow :P
Offline Pacifist
  • on hiatus
Re: Mass drop finds
« Reply #9 on: Wed, 14 May 2014, 16:01:48 »
I have worn deck caps. Want a pic?
Offline Lain1911
  • God of the Wired
Re: Mass drop finds
« Reply #10 on: Wed, 14 May 2014, 20:19:05 »
So about those double shots @_@
Offline jwaz
  • * based mod
Re: Mass drop finds
« Reply #11 on: Wed, 14 May 2014, 20:56:10 »
Worn to the point that the legends are no longer discernable?
Offline Pacifist
  • on hiatus
Re: Mass drop finds
« Reply #12 on: Wed, 14 May 2014, 20:56:42 »
Worn to the point that the legends are no longer visible?
oh not that much but the black stuff is pretty torn up
Re: Mass drop finds
« Reply #13 on: Wed, 14 May 2014, 21:13:24 »
They look quite a bit like Tai Hao.  Albeit with a Windows logo, which they said they could not do for the current GB due to licencing issues.
OEM profile - if that floats your boat (I don't mind it - there is a discussion here about it).
Offline Pacifist
  • on hiatus
Re: Mass drop finds
« Reply #14 on: Wed, 14 May 2014, 21:17:58 »
Pretty sure its 100% taihao. Those windows (or not windows) legends are a teltale sign
Offline Hak Foo
  • Make America Clicky Again!
Re: Mass drop finds
« Reply #15 on: Wed, 14 May 2014, 21:35:31 »
It's clearly Tai Hao, and it's white with green text.
Overton130, Box Pale Blues.
Offline Lu_e
Re: Mass drop finds
« Reply #16 on: Wed, 14 May 2014, 22:02:54 »
Referral links?
-_-
Maybe not... but why is the url much longer than it needs to be?
Just say NO to ABS keycaps
Re: Mass drop finds
« Reply #17 on: Thu, 15 May 2014, 01:21:52 »
Referral links?
-_-
it leeks like it's from the massdrop e-mail.
Offline Lain1911
  • God of the Wired
Re: Mass drop finds
« Reply #18 on: Thu, 15 May 2014, 01:33:44 »
Referral links?
-_-
y u no thankful :<
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
Re: Mass drop finds
« Reply #19 on: Fri, 16 May 2014, 00:43:11 »
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Sniping
Re: Mass drop finds
« Reply #20 on: Fri, 16 May 2014, 00:44:45 »
ErgoDox is back for another round if you didn't see the other thread already.
