Author Topic: Need help buying a new Mechanical Keyboard  (Read 3791 times)
Offline Jiaception
« on: Wed, 14 May 2014, 16:48:48 »
Hello everyone, I'm wanting to buy a new mechanical keyboard but I don't know which one to get  :'(
I'm planning to get blue switches, and custom key caps. It would be nice if you guys can recommend me some quality brands.
Thanks
Offline Razor Lotus
Re: Need help buying a new Mechanical Keyboard
« Reply #1 on: Wed, 14 May 2014, 16:53:03 »
Budget? $100? $200? $300?
Is your budget for base keyboard only or for the whole set including custom keycaps etc?
Form factor? 60%? TenKeyLess? Fullsized?
Some of the best brands are Filco and Ducky. Seems like you've already decided on what switch you want, so that's great too.
If you're on a lower budget, CM quickfire is a good starter board.
If you want a 60%, you can look at the poker 2 keyboards.
If you're feeling really adventurous, you can go full custom.
Offline Jiaception
« Reply #2 on: Wed, 14 May 2014, 21:04:10 »
My budget is under $150, and I think I'm getting full keyboard... Do you a god website to buy mechanical keyboard and keycaps?
Offline whiskytango
  • Don't touch the trim
« Reply #3 on: Wed, 14 May 2014, 21:22:57 »
If you're new to mechanical keyboards, this thread is a good place to start:
http://geekhack.org/index.php?topic=40501.msg803569#msg803569
Offline Pacifist
  • on hiatus
« Reply #4 on: Wed, 14 May 2014, 21:25:24 »
mechanicalkeyboards.com
Offline Rafen
« Reply #5 on: Wed, 14 May 2014, 21:26:50 »
Try out mechanicalkeyboards.com for some boards with blue switches. I would recommend Ducky or Cooler Master Quick Fire Rapid. Both of those are really nice boards and well worth the money. They also have "normal" or standard size keys so if you upgrade you can get a set and won't have to worry if they will fit or not.
« Reply #6 on: Wed, 14 May 2014, 22:42:02 »
Thanks
Welcome to Geekhack!
Letting us know what country you are in will help with regional recommendations (if you want to avoid huge shipping cost and customs fees).
Offline kohi
« Reply #7 on: Wed, 14 May 2014, 22:43:08 »
it might be a little hard to find a board and custom keycaps with a budget of ~$150; and depends what type of keycaps - but for the board alone, there are plenty of options that are around that price point ducky, qfr, filco, etc
« Reply #8 on: Wed, 14 May 2014, 22:49:37 »
Depending on location: QFR ~ $80, Tai Hao ~ $20 = ~ $100.
Offline kohi
« Reply #9 on: Wed, 14 May 2014, 22:52:45 »
oh yeah, that works. or if you're lazy and you don't want to buy custom keycaps separately, you can look into wasd v2.
but then, what if he wants pbt keycaps :p
« Reply #10 on: Wed, 14 May 2014, 22:56:58 »
Asking for recommendations of a good brand of keyboard suggests less familiarity with available options.
Hence PBT keycaps, although very nice, are not necessarily going to be at the top of the list.
Or get a Ducky board with PBT keycaps :)
Offline kohi
« Reply #11 on: Wed, 14 May 2014, 23:00:18 »
so many options, so hard to choose :))
« Reply #12 on: Wed, 14 May 2014, 23:25:40 »
Yes indeed.
Two things help:
1. Try some different keyboards before you buy, to avoid disappointment with switches, keycaps or layout.
2. Buy something now and enjoy it, rather than waiting and deciding and reevaluating and waiting again ...
Offline Defect
« Reply #13 on: Thu, 15 May 2014, 00:24:01 »
Also switch type doesn't matter because they are very easy to change out.  Layout not so much, and build quality not so much either.
« Reply #14 on: Thu, 15 May 2014, 00:59:42 »
The average new mechanical keyboard user is probably not looking forward to swapping switches on their first precious keyboard :p
Once they have tried a few switches and settled on one (or two), then comes the time to collect rare keycaps.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #15 on: Thu, 15 May 2014, 02:47:53 »
HHKB Type S
Offline kohi
« Reply #16 on: Thu, 15 May 2014, 03:03:41 »
« Last Edit: Thu, 15 May 2014, 13:32:20 by hojunski »
« Reply #17 on: Thu, 15 May 2014, 05:23:26 »
HHKB Type S
Doesn't have blue switches :(
LOL or a korean custom
Serve OP right for not mentioning his budget :p
Offline zflamewing
« Reply #18 on: Thu, 15 May 2014, 10:49:43 »
Yes indeed.
Two things help:
Rowdy has some really good advice.  This is kind of what I ended up doing.
My wife got a keyboard with Reds and every time I tried it I didn't like it.  I hit up a few local stores and tried blues and browns.  The blues felt the best to me so I ordered a Ducky Shine 2 in Blues.  I also own a CM Storm QFR and XT in blues and greens respectively.
Both brands have done well by me to date.
DK9008 MX Blues | CM QFR MX Blues | CM XT MX Greens
Offline CaptLock
« Reply #19 on: Thu, 15 May 2014, 12:46:21 »
Filco!
Offline motoyuki
« Reply #20 on: Thu, 15 May 2014, 13:11:47 »
I started with a ducky shine 3 and I love it. Seems solid to me. No problems with it at all so far.
Offline Novus
  • Mondai nothing~
« Reply #21 on: Thu, 15 May 2014, 13:18:46 »
HHKB Type S
It can if you mod it! There's no such thing as doesn't have X switch as long as you have a cheery outlook on life and a sonic screwdriver.
